dei viper 3002 alarm in a 1996 240sx
atxzenki
Posted: May 25, 2009 at 5:48 PM / IP Logged
I got a viper alarm system from a friend of mine who took it out of his car, and i want to put it in my car but i have never wired in an alarm before and don't know what they are talking about in the installation guide about the door locks and stuff. also, how do you program the alarm?
t&t tech
Platinum - Posts: 2,622
Posted: May 25, 2009 at 6:07 PM / IP Logged
vehicle year and make please, also, you should think about consulting professionals, if you're clueless that is, but, if you wanna pursue it yourself, i would be more than happy to help you
atxzenki
Posted: May 25, 2009 at 8:57 PM / IP Logged
all the info was in the title, but its a 1996 nissan 240sx. i'm gonna wire it myself. i've been doing stereos and other performance oriented electronics in my car and other cars. i would appreciate the help
t&t tech
Posted: May 25, 2009 at 9:01 PM / IP Logged
sorry didn't read it through, here's the wiring info form this site.
Constant 12V+White Ignition Switch Harness
StarterBLACK / YELLOW Ignition Switch Harness
IgnitionWHITE/ Blue Ignition Switch Harness
Ignition 2White Ignition Switch Harness
Ignition 3White
AccessoryWHITE/ Blue Ignition Switch Harness
TachYellow/Red ECM in Passenger's Kick Panel, Position 3 in 120 Pin Connector
Neutral Safety WireOrange / YELLOW
Brake SwitchRED / Green Brake Switch
Trunk PinRed (-) Anti-Theft Module
Parking LightsRED / Blue Ignition Switch Harness
Head LampRED / Yellow L And RED / Blue R at Ignition Switch Harness
Hood PinYellow/Black (-) Anti-Theft Module
Factory DisarmGREEN/ YELLOW (-) Anti-Theft Module
Door TriggerRED / White (-) Driver's Kick Panel
Door LockLight GREEN / WHITE (-) Anti-Theft Module Negative Trigger
Door UnlockBrown (-) Module above Hood Release
Horn WireYELLOW /GREEN (-) Anti-Theft Module
Windows DownLF=Blue, RF=RED / Black
t&t tech
Posted: May 25, 2009 at 9:03 PM / IP Logged
door locks are negative trigger going, i believe the 3002 has on board relays for the locks, just ground the violet wire, and use the blue/black, and GREEN/ black wires to connect to the vehicle's lock unlock triggers,
atxzenki
Posted: May 25, 2009 at 9:12 PM / IP Logged
ok cool. i haven't looked yet, but i think my car might be wired for trunk release. i know there are wires coming from it, but i haven't looked at where they go yet. i'm pretty much just figuring things out still. i just took the gauge cluster out to look at wires
atxzenki
Posted: May 25, 2009 at 9:16 PM / IP Logged
also, the wiring chart that is on this website is wrong about the starter: there are two positive wires for the starter. what do i do with those??
t&t tech
Posted: May 25, 2009 at 9:53 PM / IP Logged
yes there are two, one would be your cold start wire (if your unit does not have remote start no need to worry about this), both will read the same, but only one will prevent the starter from turning, normally the thicker one, to verify when you cut the wire, make sure the car doesn't start, if it does you have the wrong wire,if it does'nt off you go.
also i'm out for the night, laters.
Monday, May 4, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
