door trigger, 2000 tacoma
mattbabino
Posted: June 06, 2009 at 10:22 PM / IP Logged
I need some help finding the door trigger Wire on a 2000 tacoma, I have read a few wiring sheets telling me it was the black and white 2 pin connector at the top right of the fuse pannel, the one on here said it was the green and white in the drivers kick pannel. All i see in the pick up is a black wire 2 pin connector at the top right of the fuse pannel, no black and white...had the wire for the alarm system hooked up to that and it worked fine then just stopped working....I need some help here.
Platinum - Posts: 13,726
Posted: June 06, 2009 at 10:31 PM / IP Logged
GREEN / WHITE in a 12 pin connector in drivers kick panel. Hope this helps.
mattbabino
Posted: June 07, 2009 at 4:56 AM / IP Logged
Tried that one and it was only for the diriver door.....
