field disturbance sensor508d w/viper 5901
datboyvinh
Member - Posts: 7
Posted: June 15, 2009 at 6:53 PM / IP Logged
2005 Nissan Altima SE-R
I just got the Viper 5901 install and wanted to install the Field Disturbance Sensor 508D but i cant not seem to find how to install it.
The Viper 5901 comes with a built in shock sensor not like like old my alarm clifford matrix rsx3.5 where it had an external shock sensor.
Can someone please help install the 508D on my Viper 5901 alarm in details? Thanks alot
Anthony
Platinum - Posts: 13,726
Posted: June 15, 2009 at 8:51 PM / IP Logged
On the sensor, do you know which wire is power, ground and the negative trigger wire?   According to the installation manual of the 5901, the blue wire is the instant negative trigger wire.
https://www.the12volt.com/installbay/file.asp?ID=741
profuse007
Gold - Posts: 2,015
Posted: June 15, 2009 at 10:29 PM / IP Logged
these latest generation(3rd) of DEI's alarm and RS have extra 4-pin plug right next to the heavy-guage harness. You ahve the luxury to add a secondary, external, shock sensor along w/ other sensors DEI makes... or even 3rd party for that matters.
I gotta say these brain is far more superior than the last two generations.
Houston,TX
datboyvinh
Member - Posts: 7
Posted: June 15, 2009 at 10:53 PM / IP Logged
thanks for your help i found it! i guess i missed it the first time
profuse007
Gold - Posts: 2,015
Posted: June 15, 2009 at 11:10 PM / IP Logged
man, aren't you from H-I, too?
Houston,TX
Sunday, April 5, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
