xk531 on 02 liberty
godsegoizhuge
Copper - Posts: 214
Posted: July 12, 2009 at 10:58 AM / IP Logged
I just flashed the xk531 to the firmware for an 02 liberty and whenever I goto look at the manual for the said firmware, it comes up with platform 3, which is different then the manual that they show on the website. Reason I ask is in platform 3, it leaves out the section for the programming for the remote start.
Does this platform not do the remote start part for the liberty or does it?
yimke
Copper - Posts: 417
Posted: July 13, 2009 at 1:03 PM / IP Logged
do the CHDL4 v1.00 for the xk531. You need both keys though. There is some diodes involved with it, but it worked like a charm. Door locks and immobilizer bypass.
http://www.xpressdownload.com/getdocument.aspx?documentid=555
yimke
Copper - Posts: 417
Posted: July 13, 2009 at 1:04 PM / IP Logged
Also check to make sure it is made in the U.S. The last 2002 was imported from canada so a ton of the wiring colors changed for the diodes. Test and good luck.
Wednesday, March 18, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
