2001 altima wiring diagram
scottyboy
Member - Posts: 10
Posted: March 30, 2003 at 11:44 AM / IP Logged
im installing a remote start in a 2001 nissan altima. does anyone have a wiring digram for this vechile ?
jayts95
Copper - Posts: 150
Posted: March 30, 2003 at 12:41 PM / IP Logged
|       ITEM      |     WIRE COLOR     |POL|       WIRE LOCATION        |
|              12V|WHITE/ red           |+ |ignition harness            |
|          STARTER|BLACK / YELLOW        |+ |ignition harness            |
|   SECOND STARTER|BLACK/ blue          |+ |ignition harness            |
|        IGNITION|BLACK/ red           |+ |ignition harness            |
|        ACCESSORY|BLACK/ pink          |+ |ignition harness            |
| SECOND ACCESSORY|WHITE/ blue          |+ |ignition harness            |
|       POWER LOCK|gray               |- |smart entrance control *1   |
|     POWER UNLOCK|purple              |- |smart entrance control *1   |
|       LOCK MOTOR|RED / blue            |   |smart entrance control *1   |
|     UNLOCK MOTOR|yellow              |   |smart entrance control *1   |
|    DISARM DEFEAT|WHITE/ red           |   |smart entrance control *1   |
| PARKING LIGHTS +|RED / blue            |   |steering column             |
|       HEADLIGHTS|RED / yel(L),lt blu(R)|+ |steering column             |
|     DOOR TRIGGER|RED / white *3        |- |drivers kick panel or SECU |
| DOME SUPERVISION|use door trigger    |   |                            |
| TRUNK/HATCH PIN|red or RED / blue     |- |light in trunk              |
|        HOOD PIN|pink/black          |- |smart entrance control *1   |
|TRNK/HTCH RELEASE|ORANGE / black        |- |smart entrance control *1   |
| FCTRY ALARM ARM|lt GREEN/ red        |- |smart entrance control *1   |
|FCTRY ALRM DISARM|GREEN/ YELLOW        |- |smart entrance control *1   |
|       TACHOMETER|WHITE/ black        |   |6 pin plug at distributor   |
|      SPEED SENSE|PURPLE / red          |   |ECM, pin 26 *2              |
|       BRAKE WIRE|RED / green           |+ |brake pedal switch          |
|     HORN TRIGGER|brown or grn/yel    |- |steering column             |
|           WIPERS|lt grn/rd,lt grn/blk|- |steering column (L, H)      |
| LF WINDOW UP/DN|green - blue        |A |drivers window switch       |
| RF WINDOW UP/DN|RED / wht - RED / blk   |A |drivers switch or kick panel|
| LR WINDOW UP/DN|yel/red - yel/blk   |A |drivers switch or kick panel|
| RR WINDOW UP/DN|grn/wht - grn/blk   |A |drivers switch or kick panel|
Notes:
NOTE: Some models have an immobilizer system that needs to be bypassed during remote start. Use DEI module 555U to bypass. *1 The smart entrance control unit is located to the right of the steering column. It is black or blue in color. *2 The ECM is located in the front of the center console on the transmission hump. DO NOT UNPLUG THE ECM. *3 To avoid dome light delay use RED / green for the driver door, red for the front passenger door, and RED / black for the rear doors. All 3 three wires are located at the smart entrance control unit. Must diode isolate each.
scottyboy
Member - Posts: 10
Posted: March 30, 2003 at 2:26 PM / IP Logged
thanks jayts95
