08 chrysler sebring convertible
ceasar326
Copper - Posts: 239
Posted: September 25, 2009 at 1:33 PM / IP Logged
Need wiring diagram for remote start. thanks. Cesar
chev104275
Gold - Posts: 1,436
Posted: September 25, 2009 at 1:37 PM / IP Logged
Remote Start
WIRE COLOR POLARITY LOCATION
Battery RED / (+) IGNITION SWITCH HARNESS
Ignition 1 PINK (+) IGNITION SWITCH HARNESS
Accessory 1 VIOLET/BROWN
   ACCESSORY IS NEGATIVE TRIGGER THRU A 610 OHM RESISTOR.
Starter 1 YELLOW/VIOLET (+) DRIVER FENDER (NOT FOR REMOTE START)
   NOT FOR REMOTE START,
Starter 2 VIOLET/BROWN MUX IGNITION SWITCH HARNESS
   USE A 180 OHM RESISTOR FOR STARTER 2, SAME WIRE FOR ACCESSORY,
Anti-Theft Type DAIMLER SENTRY KEY® VEHICLE IMMOBILIZER
Anti-Theft Descript THE KEY SENDS AN RF SIGNAL TO THE BCM MODULE THROUGH AN ANTENNA LOCATED AROUND THE IGNITION CYLINDER
Key Sense SAME AS SECOND STARTER WIRE (-) IGNITION SWITCH HARNESS
   KEY SENSE IS NEGATIVE TRIGGER THRU A 8500 OHM RESISTOR.
Neutral Safety BLACK/ LIGHT BLUE (-) IN HARNESS TO TRANSMISSION
Tachometer UNCOMMON WIRE AT FUEL INJECTOR
Speed Sense DARK GREEN/ BROWN (AC) AT THE PCM
   PIN 32 ON THE 6 CYLINDER MODELS, IT IS IN THE BLACK/ GREEN PLUG. PIN 89 ON THE 4 CYLINDER MODELS, IT IS IN THE 96 PIN PLUG.
Parking Lights WHITE/ VIOLET (+) DRIVER KICK PANEL HARNESS
Low Crr. Pk Lights N/A
Brake Lights DARK GREEN / WHITE (+) AT SWITCH ABOVE BRAKE PEDAL
Reverse Lights WHITE/ GREEN (+) IN HARNESS IN DRIVERS DOOR SILL
Horn GREEN/ VIOLET (-) SWITCH OR CLUSTER, PIN 10, BLACK 20 PIN PLUG
Doorlocks/Windows
Power Unlock GRN/DARK GREEN OR GRN/VIOLET (-) DRIVER KICK PANEL
   PIN #15
PowerLock SAME AS UNLOCK (-) DRIVER KICK PANE
   MUST USE RELAYS. UNLOCK IS NEGATIVE TRIGGER THRU A 100 OHM RESISTOR. LOCK IS NEGATIVE TRIGGER THRU A 330 OHM RESISTOR
ceasar326
Copper - Posts: 239
Posted: September 25, 2009 at 3:57 PM / IP Logged
Thanks for the info. This is for a customer. Is it possible to make the remote start work with out an extra key. i was thinking of hiding the key in the ignition since customer dont whant to pay $240 to make a copy of the key. How can i make thins work with out an extra key and wiring.
flobee4
Silver - Posts: 585
Posted: September 25, 2009 at 4:41 PM / IP Logged
Yep, there are bypass modules for chrysler that have recently been released that you do not need to give up a key. Here is a link to one of the companies that make these modules. You will need one of their modules listed that is compatable with their CH5 software. You can also view the installation manual there.
Idatalink
ceasar326
Copper - Posts: 239
Posted: October 02, 2009 at 12:29 PM / IP Logged
Do i need to hook up the starter from the remote start brain to the car or will 2nd starter be fine. im using omegas im-532. thanks
flobee4
Silver - Posts: 585
Posted: October 02, 2009 at 11:04 PM / IP Logged
Yoou will hook up the remote starters start output to the 532's pink starter wire. On this particular car thats is the only place the remote starters start wire will go. Then the 532's Violet/white wire goes to your second starter wire Violet/brown in the car. No resistors required, the 532 takes care of all that for you. Just follow the directions for the 532. Here it is, just incase you need it.
Frank
ceasar326
Copper - Posts: 239
Posted: October 02, 2009 at 11:14 PM / IP Logged
Thanks frank got it working with compustar 5200 remote start only and used Idatalink bypass blade-al and only hooked up ignition, data in, data out, parking lights, 12volt, and ground. Blade-al did the rest.
