09 infinity g37 alarm and remotestart
tek1001
Member - Posts: 26
Posted: October 18, 2009 at 4:44 PM / IP Logged
Hey anyone have the wiring for a 2009 G37?
tek1001
Platinum - Posts: 12,488
Posted: October 18, 2009 at 9:20 PM / IP Logged
Should be the same as the 2008 seeing that it's only in it's second model year: Use a bypass module for CANBUS control and interface for conveniece features.
WIRECOLORPOLARITYLOCATION 09 infinity g37 alarm and remotestart -- posted image.
09 infinity g37 alarm and remotestart -- posted image.BatteryRED(+)UNDERDASH FUSE BOX
09 infinity g37 alarm and remotestart -- posted image.Ignition 1WHITE(+)BCM MODULE IN THE PASSENGER KICKPANEL09 infinity g37 alarm and remotestart -- posted image.
09 infinity g37 alarm and remotestart -- posted image.Accessory 1PINK(+)AT BCM MODULE IN PASSENGER KICKPANEL
09 infinity g37 alarm and remotestart -- posted image.Starter 1BROWN(-)PUSH BUTTON STARTER09 infinity g37 alarm and remotestart -- posted image.
09 infinity g37 alarm and remotestart -- posted image.TachometerRED(AC)AT ECM MODULE BEHIND GLOVEBOX
09 infinity g37 alarm and remotestart -- posted image.Speed SenseRED(AC)RADIO HARNESS
09 infinity g37 alarm and remotestart -- posted image.Parking LightsRED(+)IN HARNESS IN DRIVER KICKPANEL
09 infinity g37 alarm and remotestart -- posted image.Brake LightsWHITE(+)SWITCH ABOVE BRAKE PEDAL09 infinity g37 alarm and remotestart -- posted image.
09 infinity g37 alarm and remotestart -- posted image.Reverse LightsORANGE(+)IN HARNESS IN DRIVER KICKPANEL TO REAR
09 infinity g37 alarm and remotestart -- posted image.HornGREEN(-)IN HARNESS AT STEERING COLUMN
09 infinity g37 alarm and remotestart -- posted image.CANbusBLUE & PINK(DATA)DATA LINK PLUG 09 infinity g37 alarm and remotestart -- posted image.
09 infinity g37 alarm and remotestart -- posted image.Rear DefrostGREEN
tek1001
Member - Posts: 26
Posted: October 19, 2009 at 9:42 PM / IP Logged
Hey thank for the info what bypass mod should i use for this car?
tek1001
Posted: October 19, 2009 at 10:31 PM / IP Logged
If your using a Compustar unit with a 5200 CPU use the BLADE-AL and if your using something otehr than a Compustar, use the ADS-AL-CA. We use these modules for 99% of our installations.
Chris Luongo
Platinum - Posts: 3,746
Posted: October 20, 2009 at 10:25 AM / IP Logged
Lots of information about push-to-start Nissans on this forum. Use the search feature for the Altima; it has the same electrical system.
Whichever bypass module you choose, their respective install guides also show the car's wiring colors.
Tuesday, February 17, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
