heater blower fan
joebobrei
Posted: October 29, 2009 at 7:07 AM / IP Logged
i dont know if this is where this thread belongs but here we go
I Have a ptoblem with my 1990 integra heater. its pretty wierd and i cant figure it out. Im wondering if anyone has had the same problem. Basically my blower fan isent working properly. when i turn the switch on for the blower it shuts off my deck and it still doesent work. so i disconected me deck and checked the wiring for any wire thats exposed but everything is solid. even with my deck disconected aswell as the wiring harness it still doesent work. i even tried connecting the stock tape deck and still the same. I figure theres a short somwhere or there might be a problem with the resistors for the fan switch. the thing is sometimes it does turn on momentarily or even stay on for 10 mins so i know the blower motor itslf works fine. does anyone have any ideas ?
thx
profuse007
Gold - Posts: 2,015
Posted: October 29, 2009 at 11:03 AM / IP Logged
hondahookup.com has the service manual if you plan to test the system.
I would work backward and test the motor itself and see if any power going to it. then check the switch. i am leaning toward the switch giving your a faulty
Houston,TX
ckeeler
Gold - Posts: 1,461
Posted: October 29, 2009 at 11:28 AM / IP Logged
you have a bad ground. you need to run a new chassis ground for the blower motor.
Posted: October 29, 2009 at 12:05 PM / IP Logged
Maybe not related but Hondas seem to have a run of blower switches failing.
number2
Copper - Posts: 73
Posted: October 30, 2009 at 12:37 PM / IP Logged
Is the fan motor running smooth and strong? Or does it take a few to get up to full speed or make any unusual noise?
