clifford rsx3.5 two way signal disruption
mp5onboost
Posted: November 01, 2009 at 9:36 PM / IP Logged
Clifford RSX 3.5 two way
My car been sitting about 6mths and the alarm was working fine and all of a sudden my car isn't picking up any signal from the alarm remote. Meaning when i hit the unlock button (or any button) the car doesn't registering the signal from the remote. The remote alerts me that it cant find a signal. I will listen out.
Steve
mp5onboost
Posted: November 01, 2009 at 9:37 PM / IP Logged
I have a,
2002 Mazda Protege 5
Posted: November 02, 2009 at 2:57 AM / IP Logged
Flat battery on car or remote?
elsabaw
Member - Posts: 17
Posted: November 03, 2009 at 7:13 AM / IP Logged
My situation is somewhat similar. I have a Clifford Matrix RS III in an 01 CRV. The transmitter can send out commands to the module, lock - unlock - remote start - pop trunk. But the transmitter does not receive the confirmation beeps and the appropriate icons. This started happening after the car had a valve adjustment and window tints applied. They had to jump my car because the tinting guys had the doors open and kept rolling the windows up and down. Is there something on the car end that I need to pay attention too?
Tony G
heftylefty58
Member - Posts: 8
Posted: January 12, 2010 at 3:23 PM / IP Logged
I actually encountered this identical issue this past Sunday (Jan 10)! Fortunately, a member of another forum gave me this tip, and it fixed my issue:
Disconnect the car battery for 5 seconds (to reset the alarm device).
(FWIW, I actually disconnected the battery for five MINUTES because I incorrectly recalled his tip.)
Hope this helps!
elsabaw
Member - Posts: 17
Posted: January 12, 2010 at 6:55 PM / IP Logged
Thank you!!! Did you just disconnect the Negative terminal or both Neg and Pos terminals from the battery?
Hope this helps!
Tony G
heftylefty58
Member - Posts: 8
Posted: January 12, 2010 at 7:36 PM / IP Logged
I only disconnected the negative terminal from the car battery.
In case you're curious, here's more info: The guy who gave me the advice said that ideally, I should just disconnect the inline fuse for the "brain" of my car alarm for 5 secs. However, if this wasn't possible, then I could disconnect my car battery for 5 secs.
Well, I'm clueless about car alarms. It was pretty miraculous that I actually did find the brain, but I still wasn't able to find the inline fuse he was talking about. So, I just went with the car battery.
Good luck!
elsabaw
Member - Posts: 17
Posted: January 14, 2010 at 7:56 PM / IP Logged
Well, I disconnected the Neg for 5-6 seconds. When I reconnected, a slight spark came when reattaching the cable and the terminal. Now the CRV is not responding to any commands as if the transmitter is truly broken or it needs to be reprogrammed to the module. Can you give me any suggestions? Do I need to located the module and disconnect the fuse since the battery route did not work for me? I truly appreciate any help you can give!
Tony
Tony G
heftylefty58
Member - Posts: 8
Posted: January 14, 2010 at 11:47 PM / IP Logged
Oh man, sorry to hear about that. The good news is that the spark is normal. It happens every time I disconnect and reconnect the negative, too. I take it that you've never had to jump start a car before! Heh heh, consider yourself lucky.
Anyway, if I were you, I'd try doing disconnecting/reconnecting the battery one more time...just to see if that helps. If that still doesn't fix it, try it a third time, but this time, maybe wait 5 mins (instead of 5 secs).
If that still doesn't work, then definitely look for the fuse. Who knows--it may have blown. If so, just replace it.
I don't think you should have to reprogram the transmitter just because the brain lost power. However, hopefully some of the experienced car alarm installers can chime in.
elsabaw
Member - Posts: 17
Posted: January 18, 2010 at 4:05 PM / IP Logged
Waited 5 minutes, IT WORKED! You are a God send! Thank you again!
Tony G
Monday, May 4, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
