2002 Dodge Ram Remote Start Problem
Homicyde
Member - Posts: 20
Posted: April 02, 2003 at 5:20 PM / IP Logged
i have a dodge ram 4.7liter, and i just installed a prestiege aps-785 remote start alarm, when i remote start the alarm, the starter stays engaged until I get in the truck and put in the key. i cant find the problem...! also, the check engine light is on all the time!!!! all help will be appreciated!!!
thanks,
Chris-
Scott35
Silver - Posts: 258
Posted: April 02, 2003 at 5:30 PM / IP Logged
Are you using voltage sense or a tach wire? More than likely there is another ignition wire you need to power up.
Tacomacrew
jayts95
Copper - Posts: 150
Posted: April 02, 2003 at 5:54 PM / IP Logged
Here is the info on your vehicle. Make sure you hook up both ignitions(blue and RED / white)
and acc(orange and green) Also hook up your tach wire
       ITEM      |     WIRE COLOR     |POL|       WIRE LOCATION        |
|              12V|pnk/blk & RED / wht   |+ |ignition harness            |
|          STARTER|yellow              |+ |ignition harness            |
|        IGNITION|blue     (16 awg)   |+ |ignition harness            |
| SECOND IGNITION|red or RED / wht      |+ |ignition harness            |
|        ACCESSORY|green & orange      |+ |ignition harness            |
| SECOND ACCESSORY|blue & blk/wht *7   |+ |ignition harness            |
|       POWER LOCK|WHITE/ green *1      |- |driver kick panel           |
|     POWER UNLOCK|same wire           |   |                            |
|       LOCK MOTOR|tan/pnk or tan/blk |   |driver kick panel           |
|     UNLOCK MOTOR|blue               |   |driver kick panel           |
|    DISARM DEFEAT|tan/white           |   |passenger kick panel        |
| PARKING LIGHTS +|BLACK / YELLOW        |   |relay under hood at pwr ctr |
| PARKING LIGHTS -|purple / YELLOW *2    |   |headlight switch            |
|       HEADLIGHTS|purple / YELLOW *2    |- |headlight switch            |
|     DOOR TRIGGER|*3                  |- |*3                          |
| DOME SUPERVISION|use door trigger    |   |                            |
| FCTRY ALARM ARM|lt GREEN/ orange *4 |- |driver kick panel           |
|FCTRY ALRM DISARM|same wire           |   |                            |
| DISARM NO UNLOCK|same wire           |   |                            |
|       TACHOMETER|NOT GREEN/ orange    |   |ign coil, coil pac, injector|
|      SPEED SENSE|WHITE/ orange        |   |wht conn. 2, pin 27 @ PCM *5|
|       BRAKE WIRE|WHITE/ tan           |+ |brake pedal switch          |
|     HORN TRIGGER|BLACK/ red           |- |steering column             |
|           WIPERS|brn/wht(L),rd/yel(H)|+ |wiper motor                 |
| LF WINDOW UP/DN|lt blue - white     |A |driver window switch        |
| RF WINDOW UP/DN|brn/wht - pur/wht   |A |driver kick panel           |
| LR WINDOW UP/DN|RED / blk - blu/wht   |A |driver kick panel           |
| RR WINDOW UP/DN|grn/wht - gry/blk   |A |driver kick panel           |
|        RADIO 12V|pink               |+ |radio                      |
|     RADIO GROUND|BLACK/ green        |- |radio                      |
|     RADIO SWITCH|BROWN / red           |+ |radio                      |
| RADIO ILLUMINATE|ORANGE / blue (dimmer)|+ |radio                      |
|       LF SPEAKER|lt grn/rd-lt grn/grn|   |radio or amplifier *6       |
|       RF SPEAKER|lt blu/pu-lt blu/blk|   |radio or amplifier *6       |
|       LR SPEAKER|wht/red - wht/blk   |   |radio or amplifier *6       |
|       RR SPEAKER|tan/pur - tan/blk   |   |radio or amplifier *6       |
Notes:
NOTE: For the 2002 Ram 2500/3500, refer to the 2001 techsoft sheet. NOTE: Chrysler vehicles that use a gray ignition key have an immobilizer system that needs to be bypassed when remote starting. Use DEI part number 555C or 555U. *1 Lock requires a negative trigger thru a 820 ohm resistor. Unlock requires a negative trigger thru a 330 ohm resistor. MUST use relays. *2 Parking lights require a negative trigger thru a 330 or 1.4K ohm resistor. Headlights require a negative trigger thru a 1.8K ohm resistor. There is a rest resistance on the wire, so MUST use a relay to isolate away from the switch. *3 The LF door trigger is tan, and the LR door is tan/orange or PURPLE / orange. These wires are in the driver kick panel. The RF door trigger is tan/red, and the RR door is tan / YELLOW. These wires are in the passenger kick panel. Use all wires and diode isolate each. See directfax document #1076 for wiring information. *4 This will also do door locks. Arm/lock is negative trigger thru a 2K ohm resistor. Disarm/unlock is negative trigger thru a 480 ohm resistor. Single pulse will do disarm without unlocking the doors. Unlock requires a double pulse. MUST use relays. *5 The PCM (Powertrain Control Module) is on the passenger side firewall. *6 The amplifier is located behind the glove box. *7 These wires may not be necessary for remote start.
Homicyde
Member - Posts: 20
Posted: April 02, 2003 at 9:20 PM / IP Logged
i got the check engine light to go off by unhooking my battery for 20min. and then reconnected it, but the starter is still engaged when remote started
Homicyde-
Platinum - Posts: 12,488
Posted: April 02, 2003 at 10:28 PM / IP Logged
The RS is not programmed to the tach wire on the truck. It doesn't realize that the truck has started and is not letting go of the starter. What tach did you use ?
Saturday, February 21, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
