99 dodge caravan
bigblue06
Member - Posts: 35
Posted: November 23, 2009 at 5:24 PM / IP Logged
I'm installing a remote start on this van. It's a directed remote start. One that works off a negative input signal in order to signal for it to start. I normally tie these into the lock wire so when you press lock twice off the factory key fob it will start the car. The problem I'm having is that the locks in this van rest at ground and their is no positive input on the brain.
I thought about using a relay and flipping the power, but I dont know how well that would work on a door lock situation(maybe I'm over thinking it)
Little help?
Mike M2
Platinum - Posts: 2,652
Posted: November 23, 2009 at 5:30 PM / IP Logged
Your thinking it exactly as you should! Use a relay to flip it to negative from the lock motor leg and it will work fine...
Mike M2
Tech Manager
CS Dealer Services
bigblue06
Member - Posts: 35
Posted: November 23, 2009 at 5:43 PM / IP Logged
I'm sure I could find it if I did some diggen. But to save me some time feel like giving me a pin by pin breakdown for the relay? I haven't done much with them
t&t tech
Platinum - Posts: 2,622
Posted: November 23, 2009 at 9:03 PM / IP Logged
Wire a single pole double throw relay like this
Pin 87 and 85- ground
pin 86- to the lock leg of the actuator
pin 30- to the negative trigger input on the remote start!
bigblue06
Member - Posts: 35
Posted: November 23, 2009 at 9:18 PM / IP Logged
Thank ya sir
bigblue06
Member - Posts: 35
Posted: November 30, 2009 at 4:23 PM / IP Logged
Well I got the relay working and everything. I now have a second issue. The RS comes default for a 2 pulse start. I press lock twice and it starts. Press lock one more time and it shuts off. Every single time after that, the remote start only takes one pulse to start. Which means every time he locks the car it starts. I've tried resetting it and reprogamming it..Same results.
Any suggestions or words of wisdom?
bigblue06
Member - Posts: 35
Posted: December 03, 2009 at 11:02 AM / IP Logged
Anybody? Bueller??
Friday, March 13, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
