viper 4203v with idatalink ads tb issues
jferrarini
Posted: November 27, 2009 at 11:01 PM / IP Logged
I just installed a viper responder one remote start on my 05 F150. I have hooked everything correctly but I cannot get first or second status negative outputs to work. Ignition circuits turn one but no crank. The interface module has power, ground and ignition power. Is it possible that the outputs don't work. I have tried hooking the blue and blue/white wires to the input wire on the module with no result.
Platinum - Posts: 12,488
Posted: November 27, 2009 at 11:34 PM / IP Logged
Did the module program properly ? What firmware version are you using on the TB ?
jferrarini
Posted: November 27, 2009 at 11:43 PM / IP Logged
module programed properly the car started with the remote after cycling both keys. not sure on the firmware the box says s/w ko n1.5. I had two modules programed at the same time one for the f150 and one for a 05 explorer and the explorers remote start works correctly.
Posted: November 28, 2009 at 11:22 AM / IP Logged
When the remote start is activated on the F150, does the LED on the module start flashing GREEN ?
