thanks everyone failed rs
ladder49vfd
Member - Posts: 28
Posted: December 15, 2009 at 9:06 AM / IP Logged
Hey there folks thanks for all the help over the last two weeks really!
I attempted to install a remote start in a 2002 explorer v8, and it did not work, I ended up bringing it to the installer who I paid 250  bucks to install it.
Turns out the Xpresskit pkford XK04 was not functional. Installer needed to use another bypass. Both I and the installer tried to make the Xpresskit work, but it didn't it probably needed some firmware update that I don't have the ability to do, and he didn't use Xpresskit he uses I-data.
Moral of the story is, I tried for 2 days to make it work, but without having another part to "try" I was in a troubleshooting loop, going nowhere!
Beware the extreme do - it - yourselfer, this one can leave you scratching your head at 2 am in the morning.....
Peace
ckeeler
Gold - Posts: 1,461
Posted: December 15, 2009 at 11:28 AM / IP Logged
kudos for the effort you put in! and you came to the right place seeking advice/help. maybe the next time will go better for you.
tommy...
Gold - Posts: 1,901
Posted: December 16, 2009 at 7:28 AM / IP Logged
Maybe the hot glued chip to ignition or a universal bypass would have been easier...Next time...!
M.E.C.P & First-Class
kgerry
Platinum - Posts: 3,455
Posted: December 16, 2009 at 12:44 PM / IP Logged
problem should have been easy to troubleshoot... did you first test your install with a key slid into the IGN?    this is a basic step in any install with transponder bypass.... test the install before you move on to the transponder portion of the job.....
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
