ultra start g11 remote start, 2004 ram
catman222
Posted: December 17, 2009 at 4:32 PM / IP Logged
I have an ultra start g11 remote start and it only has one accessory output for my 2004 5.7 ram 1500 , i was wondering if this would work for relay wiring
tap acc1 from remote start to pin 86 and 87
pin 85 to ground when running on remote start
pin 30 to 2nd acc
Could someone please let me know if this would work
KPierson
Platinum - Posts: 3,527
Posted: December 17, 2009 at 4:38 PM / IP Logged
I wouldn't connect both 86 and 87 to the ACC output, I would only connect Pin 86 to it.  I would connect Pin 87 straight to your 12vdc source.  You don't want all the current from the 2nd accessory running through the 1st accessory relay.
Kevin Pierson
catman222
Posted: December 17, 2009 at 4:45 PM / IP Logged
Ok thanks for the quick reply
catman222
Posted: December 18, 2009 at 7:37 PM / IP Logged
I am installing a remote start on my 2004 ram 1500 and i need to hook a ground while running wire from my bypass module and also the second acc relay to the remote start ,could someone please tell me which way to put my diode to isolate second acc gwr
tedmond
Gold - Posts: 4,610
Posted: December 18, 2009 at 8:34 PM / IP Logged
grab 1amp diodes 1N400x series diodes. since you only want the ground to flow through, place the silver band of the diode towards the GWR wire.
