compustar p2w9000fmr 97 accord
bm107832
Posted: December 29, 2009 at 7:54 PM / IP Logged
hey, i need help, i just recently installed a compustar alarm/ remote starter p2w9000fmr with a cm4000 brain, on my 97 accord 5 speed, i can't get it to learn the tach, i have the tach wire hooked up to an injector, i dont no what can be wrong
tedmond
Gold - Posts: 4,610
Posted: December 30, 2009 at 7:22 AM / IP Logged
open up your hood, look towards your left hand side near the shock mount. you will see a single BLUE wire in a black rubber cap. use this wire. this is a tach diagnostic plug for dealers.
to program tach
1) start car and let it reach idle
2) press and hold brakes
3) hold the remote start button on the 2way until it beeps, tach is now programmed.
Ted
Compustar Expert
bm107832
Posted: December 30, 2009 at 10:12 PM / IP Logged
thank you, but the problem im having is that when i go to learn the tach, the tach doesn't learn, and the parking lights flash 3 times the once, meaning that option 2-10 isnt in the default setting 1, then i program option 2-10 to setting 1, and i go to learn the tach again, i get the same issue
05gt
Silver - Posts: 628
Posted: December 31, 2009 at 12:55 AM / IP Logged
do what was said above, the single plug with the blue wire in it, is the one you need
program tach and you should be good to go
tedmond
Gold - Posts: 4,610
Posted: December 31, 2009 at 8:18 AM / IP Logged
look in your insatllation guide how to set the unit back to default. when entering program mode, sit inside the car and make sure you hear clicks. each click will indicate what program option your on. its easier just to reset the unit. hope this helps. good luck
Ted
Compustar Expert
bm107832
Posted: December 31, 2009 at 8:22 PM / IP Logged
i hooked it into the blue wire, but i still get the same results, i looked at the guide but no reset options in there
tedmond
Gold - Posts: 4,610
Posted: January 01, 2010 at 2:02 AM / IP Logged
with two way remotes
press (1 + 2) for 3 seconds or until you hear a click from the unit
press (1 + 2) for 3 seconds or until you hear a click from the unit again
tap button 3 three times (wait for unit to click or see the parking light flash between each tap)
lights will then flash and siren chirps 3 times. if your siren is not hooked up, just hear for 3 clicks from the module. the unit is now reset in taht option menu group
start the car and let it idle, hold brakes and press the start button to learn tach again.
Ted
Compustar Expert
bm107832
Posted: January 02, 2010 at 3:35 PM / IP Logged
i found the problem, my brake wire had a loose connection, but thank you guys for your help. now i just need to deal with the clutch bypass
tedmond
Gold - Posts: 4,610
Posted: January 02, 2010 at 5:34 PM / IP Logged
from what i remember, it was a negative trigger at the clutch switch. always verify with meter.
Ted
Compustar Expert
bm107832
Posted: January 02, 2010 at 10:10 PM / IP Logged
if you don't mind can you draw me  a diagram please
