compustar 2w900fm as aux outputs
gres67gs
Member - Posts: 8
Posted: December 31, 2009 at 10:08 PM / IP Logged
Hi All
Can anyone tell me what the wire color are for Aux 1 and Aux 2 on a CM 5000, I see programing is in option group 4 but I do not see any wire designation in the manual.
Thanks.
Frank G
tedmond
Gold - Posts: 4,610
Posted: January 01, 2010 at 1:44 AM / IP Logged
aux 1 - WHITE (-) pin 15
aux 2 - VIOLET (-) pin 17
default settint is horn. so go into programming and change it for your application.
Ted
Compustar Expert
gres67gs
Member - Posts: 8
Posted: January 01, 2010 at 5:16 PM / IP Logged
Thanks, I did notice that my remote does not show aux when I tap the button so I will need to change in programming I will assume. On programming, I know the buttons on the remote will give me access to the program groups are there any other things I need to do to get into programming (like ground hood pin or valet mode)
Frank G
tedmond
Gold - Posts: 4,610
Posted: January 01, 2010 at 7:59 PM / IP Logged
no need for opeing up the hood, valet etc. just use the 2way remote and follow the sequence. The reason you are not gettting the AUX-01 on the remote, press button 4, then press button 2 in order to activate aux 1. this is just a preventative measure for accidental presses. you can disable this function in the menu.
Ted
Compustar Expert
gres67gs
Member - Posts: 8
Posted: January 01, 2010 at 9:09 PM / IP Logged
Tedmond, hate to be a bother. but can programming thru remote be disabled with the op500, seams I can not get into any option groups using my 2 way
Frank G
tedmond
Gold - Posts: 4,610
Posted: January 02, 2010 at 7:16 AM / IP Logged
with the remotes, you should be able to access all menus and do simple changes. the only things you wont be able to change are the (POS) settings, thats where the OP500 comes into play. Make sure you hear clicks from the unit in between steps. once your in that specific menu, wai tto hear X amount of clicks to verify you are in the correct menu.
Ted
Compustar Expert
gres67gs
Member - Posts: 8
Posted: January 02, 2010 at 6:39 PM / IP Logged
All is working good now, Thanks for the assistance.
Frank G
dswift
Copper - Posts: 396
Posted: January 05, 2010 at 4:36 PM / IP Logged
You need an OP500 to program your auxillaries.
"dont ground out!"
