Tach for Nissan Maxima 95
diep4554
Member - Posts: 12
Posted: April 07, 2003 at 7:40 PM / IP Logged
I tried to install Directstart 324 for Maxima 95, I tab tach wire to uncommon color and programing it but didn't work. I tried different injector but still no luck. Is it matter which injector to tab on? how do I test it? Any help will be appreciated
Scott35
Silver - Posts: 258
Posted: April 07, 2003 at 8:04 PM / IP Logged
Need to get the WHITE/ green wire at the ecm for tach. The ECM is located in the front of the center console on the transmission hump. The wiring is easily reached by removing the small black panel just to the front of the center console on the passenger side. the wire is in the middle row, 7th one in from the left.
Tacomacrew
diep4554
Member - Posts: 12
Posted: April 08, 2003 at 4:57 PM / IP Logged
That'll help. Thanks
