Clifford specific turbo timer question.
Black Se7en
Member - Posts: 9
Posted: April 08, 2003 at 12:46 AM / IP Logged
I know Clifford alarms have a built in turbo timer option.
Does anyone know how I can set this up myself?
I know it has to do with an additional relay and Auxilary Timed Output C on most G4 systems.
I just don't know how to wire it up.
Can anyone provide me info on how to do this or at least point me in the right direction?
Thanks for your time!
netZ
Member - Posts: 27
Posted: April 08, 2003 at 9:21 AM / IP Logged
you would need at least 2 12 volt relays for this to work.
Gray/Red of the Clifford's Channel C Negative Output. Program it for Timed operation.
Connect it to both Pin 85 of the 12 volt relays. Connect Pin 86 & Pin 87 of both relays to a fused 12 volt source.
Pin 30 of the 1st relay needs to be tapped to the Car side of the Ignition wire. Pin 30 of the 2nd relay needs to be tapped to the Car side of the Accessory wire.
netZ
Black Se7en wrote:
<FONT class=nf face=Verdana color=#ffffff size=2>I know Clifford alarms have a built in turbo timer option.
Black Se7en
Member - Posts: 9
Posted: April 08, 2003 at 1:56 PM / IP Logged
netZ - thanks for the reply.
I forgot one piece of imformation that might be important. I have the IntelliStart 4 installed on my car as well. Will this run into a problem with the relay setup you described? Could I possibly use the IntelliStart 4 as part of the setup? I just don't want the relay setup or the IS4 to interfere with each other.
Thanks again for your time! :)
