2010 ford explorer door pin
scooobi02
Posted: February 02, 2010 at 1:25 PM / IP Logged
Looking for help with a 2010 Explorer finding the door pin. I have tapped onto every Yellow/Gray wire down there and nothing seems to work. I have one set of wiring instructions that say it is a Positive Trigger, but none of those wires rest at 12V when the door is open. When I test for negative, none of them go to power either, using both a probe and meter.  Does anyone have any information on this?? I would greatly appreciate it. Everything else is done with the Remote Start/ Alarm but the door trigger.
Thanks!!
monty_77
Copper - Posts: 491
Posted: February 05, 2010 at 10:30 AM / IP Logged
my notes say its a
GREEN/ purple for the drivers door
Green for the driver rear door
white for the passenger door
yellow for the passenger rear door
gray/orange for trunk pin
all are located in the drivers running board or the SJB connector B(located high in the drivers kick panel)
dd pin 17
dr pin 20
pd pin 19
pr pin 21
tp pin 28
all are an open circuit
if you need help with a wiring diagram for that pm me and i will send you the one i got
05gt
Silver - Posts: 628
Posted: February 05, 2010 at 10:37 PM / IP Logged
you will need to add 2 diodes to each doorpin wire to get this to work
monty_77
Copper - Posts: 491
Posted: February 05, 2010 at 10:40 PM / IP Logged
also have to put positive through 10k ohm resistors in the diagram i got on the second diode for the trigger wire
Sunday, April 5, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
