2005 toyota tacoma pkall
f00dstamps
Copper - Posts: 132
Posted: March 13, 2010 at 6:22 PM / IP Logged
Hey guys,
I am trying to install the PKALL into a 2005 Toyota Tacoma. I am having troubles finding the 7-pin connector that has the RX and TX data wires. Can anyone assist me? Thanks in advance.
tedmond
Gold - Posts: 4,610
Posted: March 13, 2010 at 6:37 PM / IP Logged
the 7pin connector is attached right at the key cylinder. you should see it right away.
Pin 4 - RX
Pin 5 - TX
Ted
Compustar Expert
f00dstamps
Copper - Posts: 132
Posted: March 13, 2010 at 6:49 PM / IP Logged
if I post a picture of the ignition area, could you point it out to me?
f00dstamps
Copper - Posts: 132
Posted: March 13, 2010 at 6:53 PM / IP Logged
2005 toyota tacoma pkall -- posted image.
Platinum - Posts: 7,827
Posted: March 13, 2010 at 7:12 PM / IP Logged
It a black connector with 7 pins in a row.  Pin 3 is empty and Pin4 (RX) is Pink/Green and Pin5 (TX) is Light GREEN/ Red.  Should be on the ignition switch itself.  Sorry, I don't have a picture and couldn't make it out on yours.
tedmond
Gold - Posts: 4,610
Posted: March 13, 2010 at 7:15 PM / IP Logged
looks like a prostart unit?
anyways route the antenna wire and place the antenna on your windshield.
I havnt seen the connector as black, but i have seen it as white on the canadian models.
Ted
Compustar Expert
f00dstamps
Copper - Posts: 132
Posted: March 13, 2010 at 7:20 PM / IP Logged
I looked all around the ignition switch and I did not see any 7-pin connectors. I've performed about 10 RS installs so this isn't my first rodeo. I will snap some more detailed photos of the ignition switch. Is it possible that this 2005 Tacoma Access cab doesn't have an immobilizer?
f00dstamps
Copper - Posts: 132
Posted: March 13, 2010 at 7:29 PM / IP Logged
It's actually a Viper 5701. I am not done with the install yet but I plan on mounting the antenna on the windshield like you suggested.
f00dstamps
Copper - Posts: 132
Posted: March 13, 2010 at 7:34 PM / IP Logged
Posted: March 13, 2010 at 7:38 PM / IP Logged
2005 was the first year that the Tacoma got an immobilizer but it is possible that yours does not have one.  What do the keys look like?  Have you tried a remote start without the PKALL?
Monday, October 20, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
