push button start, 2003 mazda 6
desh187
Copper - Posts: 310
Posted: March 14, 2010 at 3:37 PM / IP Logged
I tried to install a isk-ll push button start on a 2003 Mazda6 with the instructions provided but as soon as i turn the ignition on with with the key,the vehicle starts.
This is what i did as to the instructions:
1x 14 gauge black wire-ground
1x 14 gauge red wire-ignition
2x identical 10 gauge blue wires
(instructions said,connect blue wire to ignition and the other blue to starter motor)
So i tapped one blue to ignition and the other to the starter wire.
Did i do something wrong? Any feedback will be appreciated.Thanks
tommy...
Gold - Posts: 1,901
Posted: March 14, 2010 at 5:05 PM / IP Logged
Sounds like it is passing the signal w/o pushing the button...You'll need a meter to test if there is output coming through the wire without pushing the button...How long does it crank...? The red wire is going to Ignition or Constant...? Did it come with in-line fusing...If not...what did you add...?
M.E.C.P & First-Class
