99 dodge durango, python 872le
chunkywolf
Posted: March 23, 2010 at 9:19 PM / IP Logged
I have just finished installing the python 872 LE, and everything but the actual starting works fine. When attempting to start, I get the error code of 8 flashes(neutral safety wire has no ground). I have checked the wire, and it is indeed grounded and well soldered. Is there anything else that might be causing this error.
sneakycyber
Silver - Posts: 413
Posted: March 23, 2010 at 10:15 PM / IP Logged
Since its a DEI product you need to ground the neutral Safety wire, Make sure the on off switch is plugged in and turned to the ON position, and have the unit programmed for AUTOMATIC for it to work. Some units IE the 5902 come default in Manual mode.
smokeman1
Platinum - Posts: 1,589
Posted: March 24, 2010 at 6:14 AM / IP Logged
I had the same issue with my Viper 5701. I forgot to plug in that On-Off toggle switch. Once I did that, it fired right up.
chunkywolf
Posted: March 24, 2010 at 12:35 PM / IP Logged
So it just needs a jumper between the RS in port and the tach threshold jumper?(I'd assume it to work the same as a switch.
sneakycyber
Silver - Posts: 413
Posted: March 24, 2010 at 12:52 PM / IP Logged
Why wouldn't you use the switch that came with the unit?
chunkywolf
Posted: March 24, 2010 at 1:12 PM / IP Logged
To answer my own question, yes, thanks for the replies!
chunkywolf
Posted: March 24, 2010 at 1:37 PM / IP Logged
Mine did not include a plug on the end of the switch leads(refurb unit). And I'd much rather not solder wires onto the control module connectors.
