relay for rear defrost
smokeman1
Platinum - Posts: 1,589
Posted: March 27, 2010 at 8:43 AM / IP Logged
This is a simple question.  I want to use a relay to activate the defroster during remote start.  I have searched the relay section and other threads but can't quite find the answer I need.
I have found the wire going to the rear defrost grid in the drivers kick panel. This wire show 12 volts when the defrost button is activated. When I cut this wire, which side of the cut wire do I connect  to which pins on the relay, and then which pin do I connect the 200ma from the R/S to, and which pin for my 12 volt source during remote start?
thanks
scrtcell
Member - Posts: 22
Posted: March 27, 2010 at 4:20 PM / IP Logged
First of all what is the year,make and model of the vehicle and then what kind of alarm/rs are you using?
shafferny
Copper - Posts: 240
Posted: March 27, 2010 at 6:43 PM / IP Logged
87a - factory rear defrost input(from BCM)
87 - 12v+ input
30 - factory rear defrost output(to grid)
85 - 12v+ input
86 - (-200mA trigger from R/S)
mitsakosopc
Member - Posts: 15
Posted: March 27, 2010 at 7:06 PM / IP Logged
Also put a diode on 87a
dereileak
Copper - Posts: 113
Posted: March 27, 2010 at 8:05 PM / IP Logged
I found my wire that when it went ground it activate it, and I just hooked it right up to the wire, no relay and it worked great, no issues so far :P
Viper 5902 - Ordered
Kicker Dual CVX 15's - Installed
Kicker ZX 1500.1 Amp - Installed
smokeman1
Posted: March 27, 2010 at 8:39 PM / IP Logged
putting this in my son's 1998  Chevy Cavalier with a Viper 5301. I have the wire going to the rear defrost grid in the drivers kick panel. This wire has 12 volts when the defrost button is on and goes to 0 volts when off.  And I know i use the blue/white 2nd status/rear defogger output wire on the R/S, most likely in a latched mode.
In looking at the different diagrams and lay outs for relays, it seems to me that 12 volts constant would cross over from pin 86 to 85 and allow 12 volts to go the r/s brain, or two 12 volt sources bucking each other.  Pin 87a and pin 30 as shafferny wrote above I understand, but i guess it's the two 12 volts on 87 and 85 that are confusing me.
Granted I've only used relay before for the dome light supervision, but this application has me confused. I don't want to do something wrong and fry the brain.  I did my taurus with just the 200ma status connected to the input wire of the defrost switch set on pulse.  So i'm looking for experience/expert guidance to steer me through my confusion.  so thats my story and i'm stickin' to it. maybe i' overthinking it.
Thanks All
t&t tech
Platinum - Posts: 2,622
Posted: March 27, 2010 at 8:55 PM / IP Logged
Ok wire like this
Cut the defrost wire and the side from the defroster (window side) goes to Pin 30
Other side goes to 87a
Pin 86 and 87 is ignition fused at ten amps
Pin 85 to the blue/white defrost wire from remote starter
Also in reference to that guy from greece, What? You put a diode across 85 and 86 band towards 86, Not 87@!
shafferny
Copper - Posts: 240
Posted: March 27, 2010 at 9:05 PM / IP Logged
t&t tech wrote:
Ok wire like this
Exactly.
When the defrost circuit is active via the R/S, it will isolate the circuit from BCM.
t&t tech
Posted: March 27, 2010 at 9:11 PM / IP Logged
Also shafferny in your initial post you had pin 85 and 86 backwards according to protocol!
tedmond
Gold - Posts: 4,610
Posted: March 27, 2010 at 9:20 PM / IP Logged
lol i do the same as you t&t.
85 is ALWAYS the ground and 86 is 12v.
Ted
Compustar Expert
