remote start on manual transmission
pinayho24
Member - Posts: 14
Posted: May 02, 2010 at 11:53 AM / IP Logged
how do you bypass the cluth
es
Moderator - Posts: 12,488
Posted: May 02, 2010 at 1:47 PM / IP Logged
Depends on the vehicle's clutch system. There are 5 different variations of clutches and requires different methods to bypass. What make, model and year vehicle is this ? Also, what remote start unit are you installing ?
pinayho24
Member - Posts: 14
Posted: May 02, 2010 at 5:25 PM / IP Logged
its a 2003 honda accord and i have a bulldog remote starter thanks for the reply i found out today that i can buy a neutral safety module for manual transmission by dei ,this is my 1st time doing this if u have more tips pls thank you.
es
Posted: May 03, 2010 at 5:20 AM / IP Logged
And you will still need to by-pass the clutch + transponder by-pass.
Saturday, December 20, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
