remote start, 2004 ford lightning?
fixmann
Member - Posts: 10
Posted: May 14, 2010 at 9:27 AM / IP Logged
Is it possible to install a remote starter on a 2004 ford lightning?
mike
dman007
Copper - Posts: 106
Posted: May 14, 2010 at 9:54 AM / IP Logged
In short Yes, and you will need an immobilizer bypass.
DTS Performance
St Petersburg, FL
fixmann
Member - Posts: 10
Posted: May 14, 2010 at 4:29 PM / IP Logged
I'am not sure what a immobilizer is?is that like a universal alarm bypass module?
mike
Platinum - Posts: 7,828
Posted: May 14, 2010 at 8:14 PM / IP Logged
Here is a link to good info on immobilizer systems.  https://www.the12volt.com/installbay/forum_posts.asp~TID~100917~PN~1
 I believe your Ford F150 Lightening has the transponder key Ford PATS3 system.
There are several good immobilizer bypasses for that application that don't require loosing a key.  .  The PKALL and PKFM from Directed are good and come pre-programmed.  Fortin makes the Key-Overide-ALL and PATS3 that will work.
fixmann
Member - Posts: 10
Posted: May 23, 2010 at 3:29 PM / IP Logged
HI,The book for the truck says it is a securelock system,but it does have a key like a transponder.(sorry I took so long to reply).
mike
