can i bypass alarm remote w/ a switch?
noweighjose
Posted: June 01, 2010 at 4:15 PM / IP Logged
The tour bus for my current job has a Viper 350HV installed on it which works as it should but my problem is that 18 people go in and out of this bus while we are on tour. We do not have a remote control for each person, instead what we did was rewire one of the original remotes to a keypad. You press 2 keys at the same time and you can arm or disarm the alarm. Works, great but with 18 people using the bus so ofter we must change the keypad so often because out 2 secret numbers start to wear off. can i bypass alarm remote w/ a switch? -- posted image.
What I would like to do is hard wire a key switch to act as the alarm's remote (lock position would arm the alarm and when you turn the key to unlock it disarms the alarm). Is there any way I can bypass the remote control and hard wire a key switch to the alarm mother board? Any suggestions are much appreciated.
peace out, cub scout!
catback
Silver - Posts: 703
Posted: June 01, 2010 at 4:29 PM / IP Logged
Just like your keypad anything can be done.
Curious why 18 people need to be able to arm and disarm the bus individually and with that many gaining access to the bus why lock it down anyway.
noweighjose
Posted: June 01, 2010 at 4:32 PM / IP Logged
We bounce around from hotel to hotel a bit, so we generally keep most of our belongings on the bus. We also have a small office in it.
Posted: June 01, 2010 at 4:57 PM / IP Logged
The correct way would be to go into the RF part of the alarm's board and change the signal via a switch but with human nature someone may forget or a thief would break in and find the switch. Frankly it would be easier for one person to hold the remote then give it to anyone who needs to use it. Also switching the main power or ground to the alarm is surely going to mess up the alarm. Also does that mean with 18 people the vehicle is left unlocked?
noweighjose
Posted: June 01, 2010 at 5:14 PM / IP Logged
The bus is storage, transportation, mobile office, etc for 18 guys that travel around in it or in another company vehicle. Having one person to hold the remote is no practical at all for us. As far as the "switch" i am talking about, I would want to wire it so the key to lock and unlock the bus would also simultaneously arm and disarm the alarm.
As mentioned before we have a viper 350hv with the remote rewired into a keypad. to arm and disarm it, one must press two of the buttons at the same time.
and howie ii, i do not understand your comment about switching the main power or ground in the alarm. i have no plans on doing so, just looking for a suggestions on how to bypass the rf part of the alarm.
catback
Silver - Posts: 703
Posted: June 01, 2010 at 10:21 PM / IP Logged
Easiest thing to do would take out your keypad and replace it with the key switch.
The better thing to do would be to install a commerical building access system on the bus. That way everyone would have their own unique card/key and access would be monitored and could be denied without having to change locks or two button codes.
Friday, March 13, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
