wiring color codes 2010 genesis coupe?
angelars
Copper - Posts: 176
Posted: June 06, 2010 at 7:33 PM / IP Logged
Does anyone have the wiring color codes for a 2010 Genesis Coupe? Will be installing a Viper 5902 Remote Start. Thanks!
Platinum - Posts: 13,726
Posted: June 06, 2010 at 8:08 PM / IP Logged
tedmond
Gold - Posts: 4,610
Posted: June 06, 2010 at 8:29 PM / IP Logged
http://www.wiringinstructions.com/v2/wiresprint.asp?recnum=10205&printsubmit=PRINT
easy access to wire on this car. most can be grabbed at the fusebox if you want to do a stealth install.
Ted
Compustar Expert
angelars
Copper - Posts: 176
Posted: June 07, 2010 at 12:57 AM / IP Logged
THANKS Guys! Appreciate it wiring color codes 2010 genesis coupe? -- posted image.
Mike M2
Platinum - Posts: 2,652
Posted: June 07, 2010 at 6:54 AM / IP Logged
Try from somewhere else other than Avox on this one if you can. I have found the the diagram for the Coupe way off from them. The sedan is spot on...
Mike M2
Tech Manager
CS Dealer Services
angelars
Copper - Posts: 176
Posted: June 07, 2010 at 11:43 AM / IP Logged
OK thanks!
If anyone has any info from another company (like DEI) then please post. Thanks!
tedmond
Gold - Posts: 4,610
Posted: June 07, 2010 at 7:23 PM / IP Logged
i got one from fortin, i will upload it later on tonight.
Ted
Compustar Expert
