remote start 02 explorer xlt
oohdatbuck
Member - Posts: 8
Posted: June 09, 2010 at 3:20 PM / IP Logged
I have a 02 Explorer XLT. I already purchased pkfm module. Could someone send me the wire connections. Thank you so much
Platinum - Posts: 7,828
Posted: June 09, 2010 at 8:19 PM / IP Logged
Two door or four door?                Wire connections for the Remote Start or the PKFM?         What Brand / Model Remote Start?
DEI PKFM install guide can be found here:   http://www.xpresskit.com/VehicleCompatibility.aspx?v=1009&ps=1
Be aware that iDatalink lists the Type C connector for the 2 door and Type B connector for the 4 door.  Different style connector, same pins 3 & 4,  same color wires but TX and RX are reversed...     DEI PKFM guide only lists Type B for the Explorer.  Look up your car on their site  and check out the ADS TB install guide.  http://www.idatalink.com/helpdesk/
 Explorer wire guide from Bulldog Security:  http://www.bulldogsecurity.com/bdnew/vehiclewiringdiagrams.asp
oohdatbuck
Member - Posts: 8
Posted: June 10, 2010 at 11:46 AM / IP Logged
4dr. I have a Viper 5101. I would like to know all the wire connections or a link where i could find them
chev104275
Gold - Posts: 1,436
Posted: June 10, 2010 at 8:04 PM / IP Logged
2002 FORD EXPLORER 4DR SUV WITH 4.0L ENGINE
Security
WIRE COLOR POLARITY LOCATION
Battery YELLOW (+) AT IGNITION SWITCH
Ignition 1 RED / LIGHT GREEN (+) AT IGNITION SWITCH
Starter 1 RED (+) AT IGNITION SWITCH
All Door Trigger BLACK/ LIGHT BLUE (-) AT CENT.JUNC.BOX UNDER LFT SIDE DASH
Domelight Super BLACK/ LIGHT BLUE (+) IN DRIVERS KICKPANEL OR INTERIOR LIGHT
LF Latch YELLOW/BLACK (-) 1 OF 16(SEC.MOD.) ALT.LOC. LFT KICK PAN.
RF Latch GRAY/RED (-) 2 OF 16(SEC.MOD.) ALT.LOC. LFT KICK PAN.
LR Latch LIGHT GREEN/ YELLOW (-) (SEC.MOD.) ALT.LOC. LFT KICK PAN.
RR Latch PINK/LIGHT BLUE (-) 7 OF 16(SEC.MOD.) ALT.LOC. LFT KICK PAN.
Trunk Trigger VIOLET/WHITE (+) 12 OF 16(SEC.MOD.) ALT.LOC.HD PIN SWITCH
   PIN #12
Hood Trigger TAN/LIGHT GREEN (-) 11 OF 16(SEC.MOD.)
   PIN #11
Alarm Disarm DARK GREEN/ VIOLET (-) POS. 5 OF 16 PIN ON FACTORY SECURITY
Parking Lights BROWN (+) HEADLIGHT SWITCH
Remote Start
Accessory 1 DARK GREEN/ LIGHT GREEN (+) IGN. SWITCH
Anti-Theft Type RF ACTIVATED SYS.
Anti-Theft Descript SECURILOCK
Key Sense GREEN/ PURPLE (+) STEERING COLUMN HARNESS
Neutral Safety WHITE/ RED (+) USE START WIRE
Tachometer 4.0=DB/LG (AC) PIN 4 OF PCM, 4.6=LG/WHT 31 OF PCM
Crankshaft Sensor DB (-) 55 OF 60 AT PCM
Camshaft Sensor DG (AC) 53 OF 60 AT PCM
Speed Sense GRAY/BLACK 8K (AC) 7 OF 58 AT PCM, OR 12 OF 20 AT GEM
Brake Lights TN/RED (+) AT BRAKE SWITCH
Reverse Lights BLACK/ PINK (+) UNDER L/S CONSOLE ,14 PIN CONN.POS.2
Horn YE/LG (-) STEERING COLUMN POS. 6 OF 8 PIN CON.
   PIN #6
Anti Theft RX WHITE/ LIGHT GREEN (+) AT PATS MODULE
Anti Theft TX GRAY/ORANGE (-) AT PATS MODULE
Modules
WIRE LOCATION
Module 1 PCM - ON PASSENGER SIDE OF FIREWALL
   PCM - POWERTRAIN CONTROL MODULE ABCM - ANTI-LOCK BRAKING CONTROL MODULE CSM - CENTRAL SECURITY MODULE
Module 2 ABCM - BEHIND DRIVERS SIDE HEADLIGHT
Module 3 CSM - BEHIND TRIM NEAR RIGHT REAR SEAT
Doorlocks/Windows
Power Unlock PINK/GREEN (-) DR. KICK
   (REV) ON MODELS WITHOUT KEYLESS
PowerLock PINK / YELLOW (-) DR. KICK
