shift position light out
kuljot
Member - Posts: 24
Posted: June 11, 2010 at 12:49 AM / IP Logged
Hi guys,
Just today I installed a rmeote start in my Dads Nissain Quest 2001.
I just noticed that the Transmission shift position light is not working on the dash. I am talkign about the light that shows if the transmission is in netural, drive, e.t.c. All the other lights are working fine on the dash. I have checked all the fuses and they are fine. Does anyone know which wire is for the Shift indicator light. Thanks.
kuljot
Member - Posts: 24
Posted: June 11, 2010 at 12:54 AM / IP Logged
Oh yeah i mean the shift position indicator light on the console. i really need help so it would be great if someone could help.
topinstaller200
Copper - Posts: 164
Posted: June 11, 2010 at 1:15 AM / IP Logged
Disconnect Negative terminal of Battery. Wait 5 min. reconnect. start car with key.
1) is selector light on? if yes(hopefully) the turn off key wait 30 sec then remote start vehicle
is light still on? yes-- problem fixed
                            no-- there is most likely a wire your not energizing when remote starting
                            double check your 2nd ign wire
                            did you actually hook up the nuetral safety switch to the nuetral safety wire? if so remove it
                             and just ground it out.
also check the harness at the gear selector switch is secure
if none of this helps you the then hit us back with the name and model alarm system you installed
also list which wires you used on it and list any complications you had while installing the alarm
all this info will better help us to diagnose you problem.
Also if you figure it out let us know what it was please?  Thanx and good luck
kuljot
Member - Posts: 24
Posted: June 11, 2010 at 12:14 PM / IP Logged
Hey topinstaller I will try that. Just to let you guys know right now even if i start the car with the key the light is still out.
Posted: June 11, 2010 at 2:18 PM / IP Logged
Is this a single light the moves with the selector, if so probably single bulb, disconnected/failed or check any plugs around the base of the gearshift.
kuljot
Member - Posts: 24
Posted: June 11, 2010 at 10:52 PM / IP Logged
Hey top installer,
I disconnected and reconencted battery. Still the same and i think the bulb is burnt out. So i was wonderign if normal auto part stores would have the bulb,
Posted: June 12, 2010 at 2:39 AM / IP Logged
Yes of course they would.
Tuesday, January 20, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
