2003 Kia sedona wiring
blichty
Posted: April 16, 2003 at 7:01 AM / IP Logged
Hello everyone,
I am new to the forum but it has allready helped me better understand the basics of alarm installs. However, I am requesting some info that I have had no luck finding and hopefully someone can help.
I have a 2003 kia sedona that I will be installing an alarm/remote start in. The only info I could find has been wiring info for a 2002. Does anyone have anything on the 2003's? Or would the wire color and locations be the same a an 02? Thank you for any additional info.
Thanks for this great site too....
Brian
CCRoadshop
Copper - Posts: 70
Posted: April 16, 2003 at 8:43 AM / IP Logged
here yuh go
12 Volts - Red & BLACK/ red       (+) Polarity    Located at the Ignition Harness
Ignition - WHITE/ blue to white               (+) Polarity      Located at the Ignition Harness
Starter - BLACK / YELLOW to Yellow                 (+) Polarity     Located at the Ignition Harness
accessory - green                       (+) Polarity     Located at the Ignition Harness
2nd accessory - white to blue                   (+) Polarity     Located at the Ignition Harness
power unlock - RED / green              (-) Polarity      Located in the plug left of steering column
power lock - WHITE/ black               (-) Polarity      Located in the plug left of steering column
brake wire - White                 (+) Polarity     Located at the brake switch
tachometer - yellow/red       Located at the instrument cluster(left Plug)(Can also use green at ignition coil under engine cover.)
parking lights - RED / black    (+) Polarity    Located in the drivers kick(harness to the rear)
door trigger - WHITE/ red      (-) Polarity    Located at the top of fuse box(
Also found green (-) behind the instrument cluster, in the left plug.
trunk trigger - GREEN/ black     (-) Polarity                Located at the instrument cluster(left Plug)
Installer - Circuit City Roadshop(2 1/2 years n counting)
Alpine CDA7894(soon to be the cda9815)
Pioneer XM unit(soon to be direct link alpine)
Audiovox 995C alarm/remote start
blichty
Posted: April 23, 2003 at 9:06 AM / IP Logged
Thanks for the info... It was much needed and will hopefully save me from pulling my hair out. :-)
Brian
CCRoadshop
Copper - Posts: 70
Posted: April 23, 2003 at 10:10 AM / IP Logged
no prob
Saturday, April 25, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
