viper 5901 rs, corolla 2010
d4rkzone
Member - Posts: 9
Posted: July 25, 2010 at 10:37 PM / IP Logged
Hi,
I recently installed the viper 5901 on my Corolla 2010. I was wondering where I need to go to program the alarm for triggering, when I smack the car a little bit? When I do that it just turn on the light (flash them) and then my 2 way remote emit the alert. But I also want the alarm be trigger.
In addition I saw other alarm (not the viper, a very cheap one) that just when you try to open the door it sounds (with the door locked), any idea of how to do this?
KPierson
Platinum - Posts: 3,527
Posted: July 26, 2010 at 4:59 AM / IP Logged
It sounds like you need to adjust the sensitivity of the shock sensor. Setting them is an art - too sensitive and they false alarm all the time, not sensitive enough and they never go off.
Some cars will turn on the dome light if you simply lift up on the door handle (even if locked). This can be used to set the alarm off on certain cars. This is a car specific feature, not an alarm specific feature.
Kevin Pierson
d4rkzone
Member - Posts: 9
Posted: July 26, 2010 at 10:56 AM / IP Logged
Thanks for reply.
If I one to set the chirp on when I lock the car, where is that option is located?
I only found in the manual how to put in silence when locking/unlocking.
KPierson
Posted: July 26, 2010 at 1:45 PM / IP Logged
Not sure what you are asking.
Kevin Pierson
Posted: July 26, 2010 at 5:43 PM / IP Logged
The chirp is on by default.
d4rkzone
Member - Posts: 9
Posted: July 26, 2010 at 11:32 PM / IP Logged
But then why when I lock/unlock it doest not chirp? It only chirp on the remote.
Posted: July 27, 2010 at 3:24 AM / IP Logged
Have you installed a SIREN? Does it sound when you trigger the alarm?
d4rkzone
Member - Posts: 9
Posted: July 27, 2010 at 10:00 AM / IP Logged
I just want to confirm that this one XK05 Programmable Platform will be compatible with the Viper 5901.
I installed the alarm with the RS but the car will not start if the key is not in the starter. So I want a method that I do not need the key in the starter to remote start it.
kgerry
Platinum - Posts: 3,455
Posted: July 27, 2010 at 10:23 AM / IP Logged
all XK product are compatible with Viper (all DEI) product....
having said that, i would still probably use an I-data piece myself......
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
d4rkzone
Member - Posts: 9
Posted: July 27, 2010 at 11:29 AM / IP Logged
Page 17 in the owner's guide :
Arm, Details: The siren in the vehicle will "chirp" once and the parking lights will flash once.
But mine only flash once... any ideas?
Its like mine is permanently in silent mode...
Sunday, November 9, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
