2011 duramax sierra
alarep5
Member - Posts: 28
Posted: August 04, 2010 at 12:46 PM / IP Logged
Did my first 2011 duramax the other day.
Same install as older models but no tach signal wire.
So I used the signal provided by the idata ADS-AL CA. Seems to work fine. Programming for 2010 Sierra seems to work fine also for door locks etc.
OLDSCHOOL - If the wire is there,...use it.
hotrodman
Member - Posts: 15
Posted: January 27, 2011 at 2:24 PM / IP Logged
I learned a lesson about tachless voltage sense last week, I install Auto Start and iData D2D , and I love the tachless feature, but the new Duramax has a feature that won't charge the battery after cold start up while the glow plugs and heated air intake are on.  So the volt gauge shows discharge for about a minute, bad thing is autostart box sees no change in charging system voltage and shuts it down after 15-20 seconds.
I did some digging and found on this 2011 GMC Duramax you can use cam sensor signal @ PCM gray connector Pin 65 DkBlu/Wht.  Ran a wire and did tach learn and stays running now.
HRM
To be old and wise, you must first be young and dumb.
adelfino
Posted: September 17, 2011 at 1:25 PM / IP Logged
let me get this straight. on the 2011 chevy duramax . if you use a immobilizer bypass such as dball from directed electronics. you dont need to tie into the heavy gauge wires for the starter . ign acc. etc.
it is all controlled by the data wire. what about locks.   do you have wire colors and locations for this truck
thank you
anthony
Platinum - Posts: 13,726
Posted: September 17, 2011 at 9:33 PM / IP Logged
thank you
anthony
This is true for many of the newer vehicles.  Door locks are also handled by the data modules.
Saturday, April 11, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
