Newbie question
tempus121
Posted: April 16, 2003 at 9:29 PM / IP Logged
I am installing my first car alarm ever and I was wondering if you guys could give me some feedback. I am deciding between 3 models.
1.)Mannix SM700   2.)Prestige APS996   3.)BlackWidow BWFM7150
***cost not too much of an issue more looking towards quality/reliability***
Also, it looks like you guys are great at giving out wiring diagrams so I was wondering if you could help me out with the wiring set up for a 2001 Ford Mustang 2001 v6. Thanks so much, this is an awesome web site and a great resource.
Paul
diabloed
Copper - Posts: 133
Posted: April 16, 2003 at 10:10 PM / IP Logged
well i can tell you from my installer view. cross out the Black Widow. they are about as reliable as far as i could throw them.
here's the wiring diagram:
12volts      yellow & lt. grn/pur      +   ignition harness
Starter          WHITE/ pink           +   ignition harness
Ignition     RED / lt. green      +   ignition harness
Second      gray / YELLOW        +   ignition harness
Ignition
Accessory   BLACK/ lt. green      +   ignition harness
Second        RED / black      +   ignition harness
Accessory
Power Lock     lt. green      +   low in drivers kick
or
Notes: Also found at the GEM module located above the drivers kick panel to the
drivers side of the steering column.
Power Unlock      purple      +   low in drivers kick
or
Parking Lights+        brown   light switch or drivers kick
Parking Lights-        WHITE/ black
Notes: Also found at the GEM module located above the drivers kick panel to the drivers side of the steering column.
Door Trigger          -
Notes: There are two door trigger wires. Use yellow/black for the drivers door and
gray/red for the passengers door. Both wires are found above the drivers kick
panel in a 20 pin connector. Use both wires and diode isoate each. See direct fax
document #1076 for wiring information.
Dome Supervision   BLACK/ white +   drivers kick panel
or
Trunk/Hatch Pin     BROWN / white      -   drivers kick panel
or
Trunk/Hatch     purple / YELLOW      +   drivers kick panel
Release
Factory Alarm    dk. GREEN/ purple - drivers kick panel
Disarm
or
Tachometer
Notes: For the 3.8L motor, use the dk. blue/lt. green, RED / lt. blue, or the
pink/white. All of these wires are found at the coil pack. The 4.6L motor uses a
separate coil for each cylinder. Go to any coil and use the wire that is NOT red or
WHITE/ lt. blue.
Brake Wire     RED / lt. green      +      brake switch
Horn Trigger     yellow/lt. green - steering column
or
Immobilizer By Pass : This vehicle has the PATS anti-theft system. Use DEI part number 555F to
bypass during remote start operation.
Sorry to make it so long.
diabloed
Copper - Posts: 133
Posted: April 16, 2003 at 10:12 PM / IP Logged
sorry it double posted
x6369x
Copper - Posts: 108
Posted: April 16, 2003 at 11:09 PM / IP Logged
From those three, I'd choose the Prestige unit. I recently installed a Mannix for a friend who bought it off eBay, and the install manual is full of typo's. And the parts they corrected, they put a sticker over.
I'd also consider the Hornet 554T, Clifford RS3, Viper 790XV, or Python 880XP (all made by DEI).
Friends Don't Let Friends Bump Stock.
diabloed
Copper - Posts: 133
Posted: April 16, 2003 at 11:18 PM / IP Logged
if your looking for something other than those three than look at the Marksman M10. i love mine. temp gauge, knock sensor, etc....
Scott35
Silver - Posts: 258
Posted: April 17, 2003 at 2:33 PM / IP Logged
The Prestige APS996 or any of the DEI products. The Prestige is fairly easy to install and it comes with 2 remotes, 1 lcd and a regular remote.
Tacomacrew
Tuesday, January 13, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
