2008 Suzuki Grand Vitara Alarm/Remote Start Wiring
saboman
Posted: September 30, 2010 at 8:20 PM / IP Logged
I need the complete wire diagram for a grand vitara 2008 and if it is the same as the 2007. I need to install an alarm with start function.
xxunknownxx
Member - Posts: 43
Posted: September 30, 2010 at 9:44 PM / IP Logged
12 VOLT CONSTANT - WHITE/ RED (+) 50 AMP
STARTER - BLACK / YELLOW (+)
IGNITION 1 - BLACK / YELLOW (+)
ACCESSORY /HEATER BLOWER 1 - YELLOW (+)
ACCESSORY /HEATER BLOWER 2 - BLUE (+)
KEYSENSE      N/A
PARKING LIGHTS ( - ) RED / BLUE (-)      @ HEADLIGHT SWITCH or BCM, (24-PIN PLUG), PIN 11, NOTE #2
PARKING LIGHTS ( + )RED / YELLOW (+)      in DRIVERS KICK or FUSE BOX, (20-PIN PLUG), PIN 4
POWER LOCK - PINK/BLACK (-), TYPE B      in DRIVERS KICK PANEL or BCM, (40-PIN PLUG), PIN 27, NOTE #2
POWER UNLOCK - PINK/GREEN or WHITE/ GREEN (-), TYPE B      in DRIVERS
KICK PANEL or BCM, (40-PIN PLUG), PIN 26, NOTE #2
LOCK MOTOR WIRE - BLUE/RED (+)
DOOR TRIGGER - BLACK/ ORANGE (-)      in DRIVERS KICK PANEL or BCM, (40-PIN PLUG), PIN 39, NOTE #2
DOMELIGHT SUPERVISION - BLACK/ RED (-)      @ FUSE BOX, (16-PIN PLUG), PIN 9 or BCM, (15-PIN PLUG), PIN 15, NOTE #2
TRUNK RELEASE - Use RELEASE Motor wire
SLIDING POWER DOOR      N/A
HORN      BLUE (-)      @ HORN SWITCH or BCM, (40-PIN PLUG), PIN 15, NOTE #2
TACH      ANY wire NOT BLUE/BLACK      @ Any FUEL-INJECTOR
WAIT TO START LIGHT      N/A
BRAKE      GREEN / WHITE (+)      @ BRAKE PEDAL SWITCH or in DRIVERS KICK PANEL, Harness to REAR of Vehicle
FACTORY ALARM DISARM      PINK/BLUE (-), Requires Double Pulse      in DRIVERS KICK PANEL or BCM, (40-PIN PLUG), PIN 36, NOTE #2
ANTI-THEFT - SUZUKI'S TRANSPONDER ANTI-THEFT SYSTEM, Requires Bypass Module, See NOTE #1
NOTES:
NOTE #1: SUZUKI'S TRANSPONDER ANTI-THEFT SYSTEM, Requires Bypass Module,
Part # 556u Bypass Module for REMOTE START
Part # DLPK-CANBUS MULTI for REMOTE START/DOOR LOCKS
NOTE #2: the BCM (Body Control Module) is located Under the DRIVERS DASH and to the
LEFT of the FUSE BOX.
xxunknownxx
Member - Posts: 43
Posted: September 30, 2010 at 9:48 PM / IP Logged
also IGN and starter is the same color so be sure to have your DMM handy!!
