horn output wire on cm6000 brain
jinseiitaidesu
Member - Posts: 9
Posted: October 24, 2010 at 5:18 PM / IP Logged
I am putting in a compustar cm6000 remote start and the horn trigger output wire does not function. The install manual states that the default setting is a ground pulse, but metering the wire nothing happens when I set off the panic mode, etc.
Everything else seems to be working correctly.
Platinum - Posts: 13,725
Posted: October 24, 2010 at 5:39 PM / IP Logged
What are you putting your meter on to check that?   Where are you connecting the other meter lead?
jinseiitaidesu
Member - Posts: 9
Posted: October 24, 2010 at 7:30 PM / IP Logged
I am putting the black lead from my FLuke to pin 17 of connector CN3 which is (-)250ma horn output or "the white wire".
And I am putting the red lead from my Fluke to a +12v voltage source.
I am then triggering the panic function on the cm6000 which is flashing my parking lights by actually activating the negative trigger (-)250ma 2nd parking light output on pin 3 or "the GREEN / WHITE wire" and outputting +12v on the siren wire also known as pin 20 or "the brown wire".
So I believe I know how to use my meter since I can check for a negative trigger for the parking lights correctly.
Platinum - Posts: 7,828
Posted: October 24, 2010 at 7:51 PM / IP Logged
Do you have an OP-500 programmer to verify POC #8 option?  Have you tried changing Menu 3 - 9 to see if the white wire output changes?
jinseiitaidesu
Member - Posts: 9
Posted: October 24, 2010 at 8:17 PM / IP Logged
Unfortunately I do not have an OP-500.
I did change menu option 3-9 between pulsed and constant and back again and there was no change in my readings. I am afraid that the setting for POC #8 is not in the default from the factory for some reason.
Unit is new out of the box. If I can't get this option working, I may have to take the positive output for the siren and use it to trigger a relay to get a ground for the horn. I just hate to do that, pin 17 should be a negative trigger by default.
