hyundai i30 2009 alarm wiring?
colouny
Member - Posts: 31
Posted: November 25, 2010 at 8:39 AM / IP Logged
Does any1 has the alarm/remote start wiring for this car ? I am in desperate search...
Car Audio and car security systems installer. Best in Car audio.
Platinum - Posts: 13,725
Posted: November 25, 2010 at 8:45 AM / IP Logged
Are you sure it is a Hyundai?
tedmond
Gold - Posts: 4,610
Posted: November 25, 2010 at 10:08 AM / IP Logged
if youre a "Car Audio and car security systems installer" you should be able to find all the wires you need within a few hours. You have half a donen wires down already which are at the ignition collumn.
rest are prob at kick panel or bcm of some sort.
Ted
Compustar Expert
colouny
Member - Posts: 31
Posted: November 25, 2010 at 11:11 AM / IP Logged
yup, pretty much.
wiki hyundai i30
colouny
Member - Posts: 31
Posted: November 25, 2010 at 11:12 AM / IP Logged
I know, but if it uses canbus, then i need adapter, other wise, i will have to look for the wires my self.
Anyhow thanks, ;)
Posted: November 25, 2010 at 12:48 PM / IP Logged
This and its Kia equivalent are made in Eastern Europe for the European market.
They are perceived as long lasting hatches for older people, sub Focus and Golf but much better built than anything from the likes of Renault, Peugeot/Citroen and Fiat.
Having said that going on my own experience with smaller versions, remove instrument panel and drop the steering column.
Instrument panel will give you feeds for the hatch, door triggers and left/right indicators via the warning lamps, + space (probably) to mount the control unit and wiring making it inaccessible to your thief, also allows you to access the steering column ignition etc. wires. Use a 556U by-pass, it's adequate. Door lock controls are down in the driver's kick well a la Toyota and at a guess are neg pulsing. (Give me a Japanese or Korean sourced vehicle that isn't neg).
There, job done.
t&t tech
Platinum - Posts: 2,622
Posted: November 25, 2010 at 4:11 PM / IP Logged
It's actually a nice hyundai, if i might say so, (and i despise hyundai), worked on one a while back, wasn't to hard but no info, sorry, i was working outside of my work premises, couldn't take notes.
colouny
Member - Posts: 31
Posted: November 28, 2010 at 11:51 AM / IP Logged
i must agree, it wasnt hard, no canbus. took 3 hours, to install alarm. As usual i forgot to take notes... cheers
t&t tech
Posted: November 28, 2010 at 12:16 PM / IP Logged
Cheers man, nice to meet ya, i see you've been here longer than i have, but it's the first time i've seen you around. Stick around this place gets better with every passing day. hyundai i30 2009 alarm wiring? -- posted image.
colouny
Member - Posts: 31
Posted: November 28, 2010 at 12:18 PM / IP Logged
Thanks, been longer, but i am a searcher not a poster. 95% of problems may be solved by searching! but i will try to do my best... ;)
