directwire for 06 cobalt
ragingfish
Posted: December 15, 2010 at 7:52 PM / IP Logged
can someone please provide me the directwire sheet for a 2006 chevy cobalt sedan?
i see only the 05 in the database and my understanding is 2006 differs from 2005 in some aspects. i also searched the forum and did not come across a similar request..
i just bought a python 1401 and wanted the directwire sheet to make sure i install it correctly...
thanks so much!
ragingfish
Posted: December 15, 2010 at 7:54 PM / IP Logged
sorry, i just realize i posted this in the wrong forum. forgive me!
zerepdivad
Silver - Posts: 605
Posted: December 16, 2010 at 12:32 AM / IP Logged
     Battery          RED / BLACK          (+)          AT BCM MODULE ON PASSENGER SIDE OF CENTER CONSOLE
     Ignition 1          YELLOW          (+)          IGNITION SWITCH HARNESS
     Accessory 1          BROWN          (+)          IGNITION SWITCH HARNESS
     Anti-Theft Type          GM PASSKEY IIIŽ ANTI-THEFT SYSTEM
     Anti-Theft Descript          THE KEY SENDS AN RF SIGNAL TO THE BCM MODULE THROUGH AN ANTENNA LOCATED AROUND THE IGNITION CYLINDER
     Crankshaft Sensor          YELLOW          (-)          AT ECM MODULE NEAR FUSEBOX UNDER HOOD
     Camshaft Sensor          BROWN / WHITE          (-)          AT ECM MODULE NEAR FUSEBOX UNDER HOOD
     Parking Lights          BROWN / WHITE          (-)          AT BCM MODULE IN FRONT OF CENTER CONSOLE ON PASSENGER SIDE
     Brake Lights          LIGHT BLUE          (+)          AT SWITCH ABOVE BRAKE PEDAL
     Reverse Lights          LIGHT GREEN          (+)          IN DRIVERS DOOR SILL HARNESS OR IN REARVIEW MIRROR POWER HARNESS
     Horn          TAN          (-)          IN HARNESS AT STEERING COLUMN
     Power Unlock          WHITE          (-)          GROUND THROUGH 1.5K RESISTOR TO UNLOCK
     PowerLock          WHITE          (-)          GROUND TO LOCK
     All Door Trigger          GRAY          (-)          AT BCM MODULE IN FRONT OF CENTER CONSOLE ON PASSENGER SIDE
     LF Latch          GRAY/BLACK          (-)          AT BCM MODULE IN FRONT OF CENTER CONSOLE ON PASSENGER SIDE
     RF Latch          TAN/WHITE          (-)          AT BCM MODULE IN FRONT OF CENTER CONSOLE ON PASSENGER SIDE
     LR Latch          LIGHT BLUE/BLACK          (-)          AT BCM MODULE IN FRONT OF CENTER CONSOLE ON PASSENGER SIDE
     RR Latch          LIGHT GREEN/ BLACK          (-)          AT BCM MODULE IN FRONT OF CENTER CONSOLE ON PASSENGER SIDE
     Trunk Trigger          ORANGE / BLACK          (-)          AT BCM MODULE IN FRONT OF CENTER CONSOLE ON PASSENGER SIDE
     Hood Trigger          TAN/BLACK          (-)          AT BCM MODULE IN FRONT OF CENTER CONSOLE ON PASSENGER SIDE
http://documents.audiovox.com/700812.pdf
http://documents.audiovox.com/700122.pdf
there you go enjoy the spoonfeeding.
A DMM is a beautiful thing.
ragingfish
Posted: December 16, 2010 at 2:40 PM / IP Logged
ummm...thanks for the info....
Wednesday, November 5, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
