python 991, xk01, 05 2500 avalanche acc 2
scottmt
Posted: December 19, 2010 at 10:24 PM / IP Logged
I installed the 991 with the XK01 Interface module on an 05 2500 Avalanche. Everything works great after the install. My question is on the Acc 2 wire. I have the wire but the installation manual didn't cover which wire on the 991 to connect to. This is what I've tracked down as the reason the heated seats won't start when it cold out. Unless there is something in the programming of the XK01 that I overlooked.
Scott
scottmt
Posted: December 20, 2010 at 12:25 AM / IP Logged
The unit must not have been cold enough for it to start everything. When done with work tonight it had started drivers seat and rear defrost. Thank you for looking.
Scott
Tuesday, November 25, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
