idatalink blade and omegalink blade
luvs2div
Member - Posts: 21
Posted: January 07, 2011 at 11:36 PM / IP Logged
I know you cant program the Idatalink Blade in the Omega brain and you cant program the Omegalink Blade in the Compustar brain.   But...  If the Blade was already programmed, would they be interchangeable?  Has anyone tried his?
dasbogie
Silver - Posts: 514
Posted: January 08, 2011 at 7:47 AM / IP Logged
I jammed a blade-tb branded compustar into an omega al1630edpb   and it flashed with a web loader branded idatalink just fine.  It also programmed just fine to the vehicle
Advanced
tedmond
Gold - Posts: 4,610
Posted: January 08, 2011 at 8:29 AM / IP Logged
should work fine as they all use the weblink to update.
Ted
Compustar Expert
luvs2div
Member - Posts: 21
Posted: January 08, 2011 at 8:57 AM / IP Logged
I jammed an Omegalink Blade into a Compustar and when I tried progamming it, it said bypass does not match or not compatible with.......
tedmond
Gold - Posts: 4,610
Posted: January 08, 2011 at 11:31 AM / IP Logged
try resetting the blade then flashing it.
Ted
Compustar Expert
