2003 kia spectra
coolen
Copper - Posts: 121
Posted: January 08, 2011 at 10:49 AM / IP Logged
I've got a remote start to install in a 03 Spectra. I have reviewed the info found on this site here: https://www.the12volt.com/installbay/forum_posts.asp~TID~23965
My question is whether or not there is some kind of key immobilizer? According to what I can find, there isn't, and the owner also states that there is none- but I want to be certain.
And since this site rocks!, I figured someone here would know. I also seen that the tach signal is obtained via dlc. I'm assuming that it is in the same spot as other vehicles...left side
Thanks in advance!
tedmond
Gold - Posts: 4,610
Posted: January 08, 2011 at 11:20 AM / IP Logged
check ifar.ca
Ted
Compustar Expert
coolen
Copper - Posts: 121
Posted: January 08, 2011 at 2:57 PM / IP Logged
Thanks for the reply. I checked the website, but unfortunately it has no info on the 03.
tedmond
Gold - Posts: 4,610
Posted: January 08, 2011 at 6:37 PM / IP Logged
if fortin doesnt have it listed, most likely no bypass is required.
Ted
Compustar Expert
coolen
Copper - Posts: 121
Posted: January 09, 2011 at 8:11 AM / IP Logged
Thanks again for the reply. I double checked that site and there is no listing for the 03. It starts at 05. I guess the only way to know for sure is install it lol.
The autostart site shows the TB-350 module, but who knows...I'm sure I'll figure it out quick enough.
tedmond
Gold - Posts: 4,610
Posted: January 09, 2011 at 9:32 AM / IP Logged
just go get a key cut from crappytire and if you can start the car you know there is no immobilizer.
Ted
Compustar Expert
zerepdivad
Silver - Posts: 605
Posted: January 09, 2011 at 10:40 PM / IP Logged
i thought most all Canadian kias/hyundais had chipped keys??
At least on newer ones... or did it start after a certain year?
A DMM is a beautiful thing.
coolen
Copper - Posts: 121
Posted: January 10, 2011 at 9:09 AM / IP Logged
I installed it last night, and just so everyone knows..this Spectra did not have a chipped key.
Thanks for all the replies....
