2007 dodge ram diesel high idle
monty_77
Copper - Posts: 491
Posted: January 20, 2011 at 9:15 PM / IP Logged
looking around the site it look like this is not going to work but figured i would as you all before i tell the customer. It is not possible.
The customer whats to be able to set the High Idle mode (PTO) not the cold high idle from his remote. this is where you turn on the cruise and can set the idle from 1000 to 1500 rpm.
looking at the site it looks like the cruise Control is on a bus and not possible to do this.
is this correct or does someone else have knowledge how to do this.
Ween
Platinum - Posts: 1,368
Posted: January 20, 2011 at 10:15 PM / IP Logged
did you search any dodge truck forums? the pcm, i think, has an unused contact that when grounded increases the idle speed. there is a mating terminal pigtail available, parts dept. the feature needs to be activated by the dealer though.
mark
monty_77
Copper - Posts: 491
Posted: January 20, 2011 at 10:54 PM / IP Logged
yes you have to have that plug grounded and PCM programed for it to work
but you still have to use the cruise control to set it
monty_77
Copper - Posts: 491
Posted: January 21, 2011 at 6:51 PM / IP Logged
Think i have found a solution that might work off another forum
DTR
Dodge wiring
now have to try it on this diesel
ramonfernandez
Posted: August 22, 2011 at 12:44 AM / IP Logged
Hmm, how did it do? Where you able to do what your client was asking?
diesel performance kits
Tuesday, March 17, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
