clifford avantguard 5.5 alarm brain
lee_hdi
Member - Posts: 26
Posted: February 04, 2011 at 5:58 AM / IP Logged
Hi,
I have a Clifford Avantguard 5.5 alarm system on my car. I bought CliffNet so that I can change the siren noises and things, but I can't find the "brain" where I'd plug the 3 pin white connector into.
I had a look around the engine bay, and the only thing I can see is the 454T for the alternator and the siren. Inside I can only see the Valet switch.
Any idea's where the installers might have put it? A picture would be ideal if you have one.
Regards,
Lee
lee_hdi
Member - Posts: 26
Posted: February 04, 2011 at 6:27 AM / IP Logged
Just had a look behind the glovebox and dashboard and found this. Is that the control unit? [sorry for the poor pictures, its a bit tight behind there!]
clifford avantguard 5.5 alarm brain -- posted image.
d6-karl
Copper - Posts: 51
Posted: February 04, 2011 at 7:24 AM / IP Logged
The last picture looks like a shock sensor, the first ones look like it would be the control box, best thing to do is it cut the cable ties down and have a look
lee_hdi
Member - Posts: 26
Posted: February 04, 2011 at 10:03 AM / IP Logged
Yeah that was it. Had to take the glovebox out and that so I could access it.
Still can't get the Intellistart to work though. It pulses the engine, but when you press Start it does nothing :/
Posted: February 05, 2011 at 12:44 PM / IP Logged
Actually looking at that installation it looks pretty decent, is this a Lexus?
The port for the Wiz will be on the Intellistart unit, other end to wiring plugs.
Do not use the Wiz on a G5 product, it's incompatible.
Many companies will negate any warantee if a member of the public uses the Wiz, in my experience they usually screw up all the settings, probably why the R/S fails to work, bet you've pulled out the data lead from the main unit, the plug or junction box you show in pictures two and three actually hides the brain, but why did they remove its metal casing? That negates it as a Cat l unit.
I suggest you go back to where it was installed, get them to sort out both the remote start and your new settings.
From what you've posted DON'T TOUCH IT! but then we've been here before with this conversation haven't we.
lee_hdi
Member - Posts: 26
Posted: February 05, 2011 at 5:03 PM / IP Logged
When have we had this conversation? clifford avantguard 5.5 alarm brain -- posted image.
No its not a Lexus, its a Peugeot.
The battery has been off numerous times since the alarm was fitted, so I suspect that it has just lost its settings.
I have not removed any wires or connectors from any of the units. Why would I do that? clifford avantguard 5.5 alarm brain -- posted image.
I have no idea why they removed the metal casing, infact I'm not the installer, so I didn't even know there was a metal casing.
Posted: February 05, 2011 at 6:04 PM / IP Logged
Wrong, non volatile memory, won't loose its settings.
lee_hdi
Member - Posts: 26
Posted: February 06, 2011 at 8:14 AM / IP Logged
Well how does it lose its settings over night and not work then?
I thought it might of been like a ECU whereby they reset to default settings when the battery has been off for a while.
Posted: February 06, 2011 at 9:21 AM / IP Logged
It is hence the volatile memory comment, if you have a 206 the Intellistart is probably around the BSI box and this needs looking at properly we are running around in circles here.
Go back to whoever installed it.
Posted: February 06, 2011 at 11:34 AM / IP Logged
The problem is you've either altered some settings without realising or disturbed the data cable going from the alarm ECU to the Intellistart.
My set up has been in the current car for 31/2 years and 60,000 miles, never touched it since the install.
