2007 mustang neutral safety sw?
dragonrage
Copper - Posts: 193
Posted: March 01, 2011 at 10:11 AM / IP Logged
Sister has a 2007 Mustang GT manual. She wants a remote start. In the past, I have been okay with the idea of just using the E-brake switch instead, so that it will only attempt this with the E-brake on. My reasoning was that if she did leave it in gear, she'd at least have to have the E-brake on, which should cause the car to not start or to start and immediately stall instead of moving.
However, I did read this: www.autoblog.com/2010/03/25/forum-fodder-dealer-accidentally-remote-starts-customers-musta/
They claim the E-brake WAS on and the car still moved. They likely didn't pull the E-brake up all the way, but if they did that, then the same thing can obviously happen to my sister. So I most definitely do need some sort of neutral safety switch. The car does not have one stock.
Has anyone ever added a neutral safety switch to a manual car? I would like to add a neutral safety switch, and then I would use BOTH the NSS AND the E-brake switch, making sure the car is in neutral AND the E-brake is on in order for the remote starter to work.
pitoaudiovisual
Copper - Posts: 388
Posted: March 01, 2011 at 10:56 AM / IP Logged
You should buy a remote starter that is made strictly for manual trans. CompuStar makes a good one that you have to do a sequence to make sure the car don't start in gear
Confidence is the key to any project!!
Posted: March 01, 2011 at 1:07 PM / IP Logged
Never known an ebrake to be safe, think parked downhill in say San Francisco, it wouldn't stall out, it would just keep going. You MUST install a manual safe R/S.
