black widow alarms
keldon24
Member - Posts: 9
Posted: April 25, 2003 at 8:56 PM / IP Logged
i need help installing my first alarm which is a black widow bwf250 w remote start. i have a manual transmission that i already use my parking brake and im the only one who drive it so it is not a prbloem. how can i do this and is there a wiring diagrams for the 2002 gmc sonomas that i can download. im lost on everything but i have hooked up alarms before so i know very lillte about alarms . thank you
draasch
Gold - Posts: 2,172
Posted: April 25, 2003 at 9:36 PM / IP Logged
this the alarm info:
Constant 12 volts RED IGNITION SWITCH HARNESS
Ignition 12 volts PINK IGNITION SWITCH HARNESS
Starter YELLOW IGNITION SWITCH HARNESS
Dome Light VIOLET (+) AT COURTESY LIGHT *
Trunk Pin Switch DOME LIGHT AT COURTESY LIGHT
Parking Lamp BROWN (+) AT HEADLIGHT SWITCH
Power Lock L BLUE (+) AT MODULE ABOVE ** #202
Power Unlock WHITE (+) DRIVER'S KICK PANEL
* At The BCM Located Behind The Driver's Dash In Front Of The Center Console, Tan Covers Driver's Doors,Orange Covers Passenger's Door,Blue/White Covers Rear Doors, And Pink/Black Covers The Hatch.Diode Isolation Needed Cathode (Band) Side Of Diode Faces OEM Wires. #202 See Positive Pulse Door Lock Diagram
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
keldon24
Member - Posts: 9
Posted: April 29, 2003 at 5:03 PM / IP Logged
 I have a blak widow arlarm and trying to figure out ow to put a remote start in my 2002 sonoma and it has a manual trans. the alarm is bwf250. im a little lost on what to do with it and does anyone know what to do. im the only one whoi drives it that is why i want it in it. any help wpuld be appreciated
keldon24
Member - Posts: 9
Posted: April 29, 2003 at 5:05 PM / IP Logged
o thank you
