07 kia sorento keysense
Thack79
Silver - Posts: 526
Posted: June 07, 2011 at 4:57 PM / IP Logged
keysense necessary on the 07 Kia sorento. If so is it positve or negitive and location.
Also is the 2nd accessory the radio, cigarette lighter, etc.
thanks
thecoolmankyle7
Copper - Posts: 77
Posted: June 07, 2011 at 7:06 PM / IP Logged
It should not be necessary  to hook up the keysence for remote start. Its positive if you do need it.
The best way to find out what accessory does what is to check it. You can make a jumper from the green 12v constant to the accessory wires and see what they power up. Why? are you not wanting your radio to come on with the remote start? Sometimes one accessory can be the blower motor and the other can turn on the compressor, sometimes you do need them both.. some times you dont. If it were an ignition wire I would say you have to hook it up but you can normaly play with the acc wires to active the ones you want to come on, heck back in the day we check what the wire did with out diagrams and determind what needed to come on when. (always verify all of you wiring with a meter or test light)
If you are not wanting to the radio to come on you can put a relay on the acc wire at the radio with the ground when running wire to break the current untill the remote start cuts off. So when you get in and put the key in and press the break pedal the radio would come on.
Posted: June 08, 2011 at 7:24 AM / IP Logged
X 2 with "thecoolmankyle7"
Tuesday, November 4, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
