anti jacking and starter kill cm6000
cousinit99
Member - Posts: 14
Posted: July 26, 2011 at 1:15 PM / IP Logged
Ok, I'm working on a Compustar CM6000 and I want to use both the starter-kill and anti-jacking features.  Anyone know anything about this?  It is possible, right?  Wire in the standard starter-kill relay, and then cut the vehicle ignition wire and install a second relay, normally open, using the 2nd ignition (-) output on the  for the trigger, as illustrated below.   Would this work?
anti jacking and starter kill cm6000 -- posted image.
awdeclipse
Copper - Posts: 285
Posted: July 29, 2011 at 8:57 AM / IP Logged
So the 2nd Ignition output is active when the alarm is disarmed?
You would need an output that is active during disarm if you wire the relay in that fashion. From what I remember, starter kill is usually "active" when the system is armed. The starter kill relay is energized when the alarm is armed.
With an "active" Ignition Kill you run the risk of being stranded in the event of a relay failure. If that is something you are comfortable with, then follow the standard Normally Closed Starter Kill diagram, but replace the starter wire with the Ignition wire.
Starter Kill Normally Open
Platinum - Posts: 7,828
Posted: July 29, 2011 at 9:40 AM / IP Logged
Here is how Compustar describes "Anti-Jacking".  It uses the pre-wired Starter Kill relay. If the Compustars Remote FOB signals a panic, it interrupts the vehicles Ignition wire after a 30 Siren alert period.
3-04 Starter-Kill – This option determines the mode of the anti-grind/starter-kill relay.
Default 1: Anti-grind + starter-kill
Option 2: Anti-grind only (no starter-kill)
Option 3: Anti-grind + passive starter-kill: starter-kill activates in 45 seconds after ignition is turned off.
3-05 Anti-Jacking – This option requires the starter-kill relay to be wired to the ignition vs. the starter wire.
Default 1: Acts like starter-kill: removes power from the ignition, which allows the car to crank but not
start.
Option 2: Turns on anti-jacking: when the remote panics the system, power from the ignition will be
removed at the end of the 30 second siren duration, thereby disabling the vehicle.
Option 3 & 4: Only available with Canadian remotes.
IMPORTANT: When using ignition-kill on manual transmission vehicles Option 2 will need to be
utilized. Option 2 disables the anti-grind circuit while the vehicle is remote-started; if the anti-grind
circuit is active and the start-kill relay is installed in the ignition, the relay will “buzz” while remotestarted.
You could use the Compustar relay and Program 3-05 to Option 2 for Anti-Jacking and add a Basic Starter Kill relay circuit to the Starter wire.  ( Not familiar with the Canadian Compustar versions.)
cousinit99
Member - Posts: 14
Posted: July 29, 2011 at 2:05 PM / IP Logged
Thanks guys, I learned something..  I was wiring the relays backwards anti jacking and starter kill cm6000 -- posted image. (as awdeclipse pointed out)..
@kreg357 - Yea, I'm a little excited because I have the Canadian system.  It has an IC ID so I curious as to whether it auto locks/unlocks.  I'm going to investigate this option in particular and find out.  I'll let you know once I a make a discovery or two..
Thanks again guys
cousinit99
Member - Posts: 14
Posted: July 29, 2011 at 2:06 PM / IP Logged
"relay", not relays..  wow, I miss the Edit Post button right now..
Tuesday, April 28, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
