make my trunk button work
bored`n`def
Member - Posts: 23
Posted: October 27, 2011 at 8:09 PM / IP Logged
Hey guys. I have a 2006 mitsubishi galant, and i had a local dealer install a Scytek Galaxy Mobile 5000. He says that the trunk can't be opened with the remote (which is BS, because the factory remote does it just fine).
What do i need to do or look at having done to get it working?
Factory remote has trunk button (that works)
Interior has lever to open trunk
If there is any more info that is needed, let me know make my trunk button work -- posted image.
Platinum - Posts: 7,828
Posted: October 27, 2011 at 8:29 PM / IP Logged
TRUNK RELEASE        GREEN / WHITE (5 WIRE)                        @ ETACS ECU, PIN 32, See NOTE *1
NOTE *1 ETACS (Electronic Timing/Alarm Control System) ECU (Electronic Control Unit) IS ATTACHED TO THE BACK OF THE FUSEBOX.
http://www.bulldogsecurity.com/diagrams/extrainfo/diagrams/14301_GALANT_5-WIRE%20TRUNK%20RELEASE%20DIAGRAM.pdf
Pin 18 GRAY WIRE: Auxiliary 1 Output (-) 500 mA. Connect to a relay for an optional feature such as trunk release, etc. This output may be programmed for momentary, timed, or latched operation.
Posted: October 28, 2011 at 2:36 AM / IP Logged
Use a 5 pin Bosch/Tycho relay, all auto parts stores or Radio Shack as follows:-
Cut the GREEN / WHITE.
ETACS side to 87a.
Trunk side to 30.
12v+ constant, fused 15 amp to 86 and 87.
Grey wire to 85.
Place a 1N4004 diode, Radio Shack, in line on the grey with the band away from the relay to protect things.
flobee4
Silver - Posts: 585
Posted: October 28, 2011 at 6:51 AM / IP Logged
You need a 5 PIN Bosch relay. Radio shack only has 4 Pin Relays. I briefly looked at autozone's relay the other day and it only had 4 pins too.(unless they had another one someplace else). Best bet, run into your local stereo shop and ask for one. Just make sure it has 5 Pins on it.
bored`n`def
Member - Posts: 23
Posted: October 28, 2011 at 10:44 PM / IP Logged
Thanks alot guys, i will be checking this out, and hopefully getting it fixed myself soon!
Saturday, April 11, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
