no ign output
d3rrick
Posted: October 29, 2011 at 6:23 PM / IP Logged
I'm installing a viper 5301 on a 2008 titan and I'm not getting any ign 1 output from the viper. If I try to start it without the key in the lights in the dash flash and nothing happens. If I put the key in the ON position the starter engages but at no time does the Ign wire put out 12V. Any Ideas? I should also say that this is a factory referb.
smokeman1
Platinum - Posts: 1,589
Posted: October 29, 2011 at 7:38 PM / IP Logged
What other wires from the heavy gauge harness do you haave connected?  Do you have the fused wires connected to a constant 12 volt source?
d3rrick
Posted: October 29, 2011 at 8:06 PM / IP Logged
H3 is as follows and I have the constant 12V on H1
Pink - Ignition Input/Output - Ignition wire
RED / White - Flex polarity feed (prog as 2 starter) - 12V
Orange - Acc Output - ACC wire
Violet - Starter Output - Starter 1 wire
Red - Ign 1 ploarity feed - 12V
Pink/White - Flex output - Strater 2 wire
RED / Black - Starter polarity feed - 12V
Posted: October 30, 2011 at 5:58 AM / IP Logged
Did any one mention a by-pass and whether one is required?
d3rrick
Posted: October 30, 2011 at 12:05 PM / IP Logged
I've tried with the key in the ignition too, rulling out the bypass. Also, I belive even without a bypass the Viper would still try to put the power out.
Posted: October 30, 2011 at 12:22 PM / IP Logged
Your wiring appears correct, check the 12V inputs at the 5301 "brain" against a good ground, then check the ign 1 output, pink I believe, see if it's actually showing 12v+ when you engage the RS.
If your inputs re all OK and it still doesn't produce the 12v+ on activating the RS then you have a faulty unit, not a problem that seems to have come up with these.
d3rrick
Posted: October 30, 2011 at 10:01 PM / IP Logged
The 12V signals are good going in. Still no 12V from the Brain. As I said this is a referb so it was a small gamble to begin with. The Dealer I got it from is going through these same steps with me via email then we'll work a swap. Hope it is the box. It's getting cold here in Alaska.
d3rrick
Posted: November 06, 2011 at 4:04 PM / IP Logged
Figured it out. There are a few K Ohms sitting on the brake wire even when it is not pressed. Waisted hours on theis one.
Thursday, November 6, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
