astroflex 800 remote
iskidoo
Silver - Posts: 1,047
Posted: November 03, 2011 at 7:53 AM / IP Logged
Hi, I am trying to help a friend replace a lost remote for used vehicle that they bought that has an Astroflex 800 under the dash. Any idea which remote(s) will fit this. Possibly a picture of the proper remote?
Thanks for any help you could offer.
Steve G
monty_77
Copper - Posts: 491
Posted: November 04, 2011 at 9:15 AM / IP Logged
The original remote is no longer available.
Astroflex list several alternatives
here are the
613-TX three button no sound
611-TX one button
711-TX one button
2514-TX four button with sound
310-052-300-10 6 button with sound
i can get pics the remotes but have to get home to my work computer
tron_1
Posted: June 01, 2012 at 5:14 PM / IP Logged
I have a model 800 asnd lost the remote. I found a 6 button remote but I am having problems programming it. I tried dip sw 8 up, hit the brake once, press any button on the remote, dip sw down & hit the brake once more. It seems I have to do a long press or the car wont start. When it starts, it stops 1 sec later.
monty_77
Copper - Posts: 491
Posted: June 03, 2012 at 10:42 AM / IP Logged
astrostart remotes have a long button push you have to hold them for about a 1.5 seconds to 2 seconds before they transmit.
also after it starts and then fails what it the led flashing it will repeat a code for the failed start attempt. do not hit brake before you count the flashes
i am betting its a 4 flash then repeat, for on tach signal and you will ave to check the tach wire connection
if it is anything else let me know and i will try to help
