need tech sheet for a 96 pontiac Trans AM
emorse2323
Copper - Posts: 106
Posted: April 29, 2003 at 3:54 PM / IP Logged
I heed a tech sheet for a 1996 pontiac trans am also i need to know what type of door lock system it has?
thanks
Platinum - Posts: 12,488
Posted: May 01, 2003 at 8:27 AM / IP Logged
|              12V|red                 |+  |ignition harness            |
|          STARTER|yellow              |+  |ignition harness            |
|         IGNITION|pink                |+  |ignition harness            |
|        ACCESSORY|orange  must enable |+  |right of dr.kick panel      |
|       POWER LOCK|RED / black           |-  |BCM in pass kick            |
|     POWER UNLOCK|tan & gray/black *2 |5wi|BCM in pass kick            |
|       LOCK MOTOR|gray                |   |BCM in pass kick            |
|     UNLOCK MOTOR|tan                 |   |BCM in pass kick            |
|    DISARM DEFEAT|gray/black          |   |BCM in pass kick            |
| PARKING LIGHTS +|brown               |   |drivers kick panel          |
|       HEADLIGHTS|yellow              |+  |                            |
|     DOOR TRIGGER|gry/blk and blk/wht |-  |BCM in pass kick *3         |
|  TRUNK/HATCH PIN|ORANGE / black        |-  |BCM passenger kick          |
|TRNK/HTCH RELEASE|BLACK/ white         |+  |relay near pass. kick       |
|  FCTRY ALARM ARM|*5                  |   |                            |
|FCTRY ALRM DISARM|*5                  |   |                            |
|       TACHOMETER|white or RED / black  |   |coil/dist. assembly *1      |
|       BRAKE WIRE|light blue          |+  |at brake switch             |
|     HORN TRIGGER|black               |-  |black conn. st. column      |
|           WIPERS|green or gray       |+  |black conn. st. column      |
|  LF WINDOW UP/DN|dk. blue - brown    |A  |in drivers door             |
|  RF WINDOW UP/DN|lt. blue - tan *4   |A  |in drivers door             |
Notes:
NOTE: This vehicle is equipped with VATS.  *1 White-V6, RED / black-V8. Location is front of left cylinder head for V6 and at a 4 pin plug at the passenger side valve cover for the V8.  *2 The tan will unlock the drivers door and the gray/black will unlock the passenger door.  Wire each as a 5-wire system with separate relays. See direct fax document # 1052  *3 Seperate left and right door triggers, diode isolate.  *4 Bypass module for drivers window and connect directly to motor leads. In passenger door motor wires are dk. blue and brown.  *5 Some models are equiped with a factory alarm. The only way to disarm these alarms is with the factory remote or turning on the ignition. To turn off the factory alarm, see direct fax document #1051.
Wednesday, February 25, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
